       2       3       4       end
50-150mm F2 Review
tester_V
p.1 #1 · 50-150mm F2 Review
Found this video online, looks interesting but too heave for me.
Apr 22, 2025 at 11:56 PM
PixiPhotography
p.1 #2 · 50-150mm F2 Review
Not sure this makes sense (price and focal length) over a very good, lighter and cheaper 70-200 GM II or a really versatile Tamron 35-150 F2.
Edited on Apr 28, 2025 at 04:56 PM · View previous versions
Apr 23, 2025 at 02:00 AM
aCuria
p.1 #3 · 50-150mm F2 Review
PixiPhotography wrote:
Not sure this makes sense (price and focal length) over a very good, lighter and cheaper 70-200 GM II or a really versatile 35-150 F2.
It really depends if your subject benefits from OSS or 1 stop of light.
70-200/2.8 GM II
  1. Internal Zoom
  2. OSS
  3. Longer fl (200mm)
  4. Takes TCs for 280/4, /400/5.6
  5. 1045g
  6. 0.3x Magnification (Fills frame with >8cm subject)
50-150/2 GM
  1. Internal Zoom
  2. Wider fl (50mm)
  3. 300/4 equivalent (cropped)
  4. 1340g
  5. 0.2x Magnification (Fills frame with >12cm subject)
35-150/2-2.8
  1. No Internal Zoom
  2. Wider fl (35mm)
  3. 300/5.6 equivalent (cropped)
  4. 1165 g
  5. 0.17x Magnification (Fills frame with >14cm subject)
  6. 35-38mm = f/2
  7. 39-58mm = f/2.2
  8. 59-79mm = f/2.5
  9. 80-150mm = f/2.8
Apr 23, 2025 at 02:04 AM
PB_James
p.1 #4 · 50-150mm F2 Review
70-200/2.8 GM II
  1. Internal Zoom
  2. OSS
  5. 1045g
50-150/2 GM
  1. Internal Zoom
  2. Wider fl (50mm)
  4. 1340g
35-150/2-2.8
  1. No Internal Zoom
  2. Wider fl (35mm)
  4. 1165 g
  6. 35-38mm = f/2
  7. 39-58mm = f/2.2
  8. 59-79mm = f/2.5
  9. 80-150mm = f/2.8
Perfect comparison summary of the relevant points. Better than the online revierews!
Apr 26, 2025 at 12:13 PM
aCuria
p.1 #5 · 50-150mm F2 Review
PB_James wrote:
Perfect comparison summary of the relevant points. Better than the online reviewers!
Maybe they need to make the video a certain length to get paid by YouTube haha
I did get the chance to try the 50-150 for a couple of hours... from an ergonomics perspective the lens is back-heavy. This means when holding the lens by the zoom ring, the camera will want to tip backwards.
In contrast a lens like the 200-600 wants to tip forwards. I suppose back heavy is much better than front-heavy, but it would be better if it were balanced near the focus ring.
Compared to the 70-200GMii, Sony made the focus ring really big this time even though the lenses are the same length.
Weight wise the 50-150 feels like using those older 70-200 lenses, like the 70-200GM v1 or EF 70-200/2.8 lenses.
idk if its worth so much more money than the 70-200GMii though
Apr 27, 2025 at 11:58 AM
Jimi3
p.1 #6 · 50-150mm F2 Review
You likely weren’t testing for this, but I’m wondering if you think it’s at all hand-holdable with one hand for short periods while shooting. When it becomes available used, I might consider it for dog portraits - people too, but for dogs, I’m often removing my left hand to get attention with toys or noise makers. This is easily doable with the 28-70 f/2, but I think I’d prefer a bigger working distance like the 50-150 would provide. Do you think I could shoot one handed for a few seconds at a time, maybe with a hand strap, or am I dreaming?
Apr 28, 2025 at 01:58 PM
freaklikeme
p.1 #7 · 50-150mm F2 Review
It's doable, but you're not going to maximize image quality that way. For dogs, I carry a little squeaker I can press up against the lens while I'm holding it and a plastic whistle I can just hold in my mouth when the squeaker isn't doing it.
Apr 28, 2025 at 03:50 PM
Jimi3
p.1 #8 · 50-150mm F2 Review
Thanks. I’ve used some duck calls with good effect, and it really only takes a moment to get them to my mouth for use. So maybe this lens would be workable. But holding a squeaker along with the lens is a great idea too. I’ll have to get my hands one of these lenses when they come in and see if it might be feasible, though I’d probably have to sell my 28-70.
Apr 28, 2025 at 06:23 PM
aCuria
p.1 #9 · 50-150mm F2 Review
I think you can do it. Better use a neck strap so accidents don’t happen
Apr 28, 2025 at 08:01 PM
JohnDizzo15
p.1 #10 · 50-150mm F2 Review
I keep doing mental gymnastics trying to figure out a use case for when I would actually prefer this thing over a plethora of other options while considering the key factors for myself (size/weight, FL, aperture, and price).
Without fail, I’ve ended up at the conclusion that this thing would very likely end up sitting in my closet most of the time, only making occasional appearances when I forcibly bring it out. So then what I’m left with as the sole motivating factor to get this thing is boredom and/or a little bit of play time.
Generally speaking, when I need to cover wide to short tele for a given scenario, I just bring two rigs out, and there is seldom ever an instance where I’d be satisfied being capped at 50 on the wide end, and 150 on the long end.
While a very cool and welcomed lens to the ecosystem, I feel like it just sits uncomfortably in this in-between space for my personal preferences. Not wide enough, not long enough, and not quite fast enough for a one rig outing. So if I carried this thing out, I’d always have a second rig with me that was wider than 50 and faster than f2. And if I’m doing that, then I’d rather combine it with something that made it out to 200, albeit at 2.8.
All that being said, I’ve been known to succumb to boredom many times in the past.
Apr 29, 2025 at 09:50 AM
GMPhotography
p.1 #11 · 50-150mm F2 Review
This is the same for me. It really just don't fit in the system for me. I think best bet if you have to force it into your system than I agree it may just sit in a cabinet. I mean it could be handy I have the 16-25 and 24-50 so 3 lenses I can go 16-150 which covers a lot but still makes no sense
Apr 29, 2025 at 09:58 AM
aCuria
p.1 #12 · 50-150mm F2 Review
A 3 lens kit with 16-25, 24-50 and 50-150 makes no sense to me.
Personally I plan around 1 or 2 lenses in the bag.
This could be a 2 zoom lens kit, a 2 prime lens kit for low light or just 1 lens when traveling light. The other lenses stay in the hotel or at home.
This also has the advantage of translating to 2 cameras if i had to shoot something seriously. I know some of you guys use 3 cameras at once but its too much for me to handle.
16-35 and 70-200 has worked for me for a long time.
A 16-35 and 50-150 should also work fine, albeit with different tradeoffs
Apr 29, 2025 at 10:44 AM
freaklikeme
p.1 #13 · 50-150mm F2 Review
I think it was awfully nice of Sony to make the perfect companion to Sigma's 28-45/1.8.
Apr 29, 2025 at 08:30 PM
aCuria
p.1 #14 · 50-150mm F2 Review
I used to shoot with the 135L, which produced beautiful images, but I didn’t use it often. In typical low-light situations, my primary lens was usually a 24mm f/1.4 or 35mm f/1.4, and if I carried a second lens, it would be a 50mm, 85mm, or 90mm, making the 135L my third-choice lens. In good lighting, I preferred using the 70-200mm.
As a result, the 135L mostly saw use at home or during indoor concerts and sports. That’s why I never picked up the GM version, since I knew I wouldn’t get enough use out of it.
The 150mm f/2 and 200mm f/2.8 are equivalent to 300mm f/4 when cropped. If both optics are perfect, theoretically they should resolve distant subjects equally well. However, this needs to be verified through empirical testing on high-resolution sensors.
For travel, a four-lens setup could be the 16-35mm, 70-200mm, 24mm f/1.4, and 50mm f/1.4. This could be streamlined into a 3 lens kit with the 16-35mm, 50-150mm, and 24mm f/1.4.
On its wide end, the 50-150 loses 1 stop compared to the 50mm f/1.4 or 85mm f/1.4, but it offers the flexibility of a zoom.
On its long end it may effectively replace both a 70-200mm and a 135mm f/2
Apr 29, 2025 at 09:14 PM
MAubrey
p.1 #15 · 50-150mm F2 Review
Exactly my thoughts. I'd like to see Sigma follow suit, though, with Sigma pricing rather than Sony pricing!
Apr 30, 2025 at 06:40 AM
cambyses
p.1 #16 · 50-150mm F2 Review
Maybe it’s just me, but the biggest selling point of my Tamron 35-150mm f/2-2.8 is its 35mm wide end—it usually saves me from needing to carry a separate 24-70mm lens. That’s why, when I travel these days, I always reach for the 35-150 instead of packing both a 24-70 and a 70-200. Personally, 50mm just doesn’t feel wide enough for most of the perspectives and compositions I prefer. I get that designing a 35-150mm with a constant f/2 aperture would’ve been a much bigger engineering challenge for Sony, but I still wish they had made it happen!
Apr 30, 2025 at 11:44 AM
aCuria
p.1 #17 · 50-150mm F2 Review
Makes sense if 35mm is wide enough, but I usually carry a 16mm
I think the 35-150 is more suited for a 2 lens setup... For single lens there's the 20-70G, 24-70GM, 28-70/2...
Apr 30, 2025 at 11:54 AM
cambyses
p.1 #18 · 50-150mm F2 Review
Yes, if I am going somewhere where I specifically expect to use wide angles, then I'd carry my 16-35, or even my Nikon camera with 19mm PC-E lens! But everywhere else, 35mm is usually wide enough for me but not 50mm!
Apr 30, 2025 at 06:26 PM
aCuria
p.1 #19 · 50-150mm F2 Review
I agree with you that 50mm is not wide enough, because for low light I may use a 24/35mm prime alone but not a 50mm prime.
However if I use a single zoom its usually a 16-35
I would not carry a lens like the 70-200, 50-150 or 35-150 by itself.
If i had to use one zoom lens forever, 20-70 or 24-70 is more palatable.
May 01, 2025 at 08:24 AM
hatch1921
p.1 #20 · 50-150mm F2 Review
Just dropping this in here for an FYI - Sony FE 50-150mm f/2 GM Lens (Sony E) is now in stock!
As of 5/25/25 - 3:12 AZ time. B&H sent the update if anyone is in the market.
Hatch
May 25, 2025 at 05:12 PM
       2       3       4       end
       2       3       4       end
