Archive 2023 · Oregon Cascading
Mark Metternich
p.1 #1 · Oregon Cascading
I think a person could spend many lifetimes exploring and photographing Oregon full-time and not even start to get close to experiencing all its most epic, and diverse beauty. I hope you get the chance to try! 😁
Gear:
Sony A7R2 (I shoot with the Panasonic Lumix S1R now, for those who have been asking)
Canon 11-24@11mm
f/10
1.0 second
50 ISO
I might have used the Wonderpana circular polarizer for this one (which I never use anymore).
Post-processing:
In Camera Raw, starting with a Linear Raw Profile (the real original file), I made a Custom Raw Profile (starting point) by applying a custom global gamma (brightening) curve mask (2.2), then a separate endpoint curve mask (locking in the white and black points without clipping), then a separate mid-tones curve mask, then lastly a separate global contrast mask with the saturation brought in a bit. With the heavy lifting easily done, this made the image nearly done before sliding even a single slider in Camera Raw! This was massively labor-saving and a noticeably huge leap in quality compared to any Adobe profile.
After finishing a few very subtle slight adjustments to the raw file in Camera Raw, I automatically applied all the same settings to another bracketed version taken at 1/60th of a second to stop the foliage movement. That one had a lot of noise and was originally quite dark. After matching the luminance of both files I brought the first (1-second exposure) into Photoshop as a lossless Raw Layer. The raw file was taken into DXO Photolab ONLY for their secret sauce noise reduction, then I exported that raw file into Photoshop onto the Raw Layer Stack. I applied a mask, and then brushed out the moving foliage, then rasterized (flattened) the image, and from there I did the fine-tuning and clean-up.
With the mega breakthrough of both totally lossless Raw Layer Editing (not Adjustment Layers or Smart Object Layers - which are destructive/degrading/damaging - but working in actual lossless Raw Layers) and starting from the original Linear Raw File and doing the most essential, influential, and powerful adjustments based specifically on an images very unique needs, what is possible today in terms of both labor-saving ease and quality is just astonishing!
Edited on Mar 01, 2023 at 01:03 PM · View previous versions
Feb 28, 2023 at 06:58 PM
DopamineHunter
p.1 #2 · Oregon Cascading
Mark,
Freaking awesome!
Feb 28, 2023 at 07:07 PM
junglialoh
p.1 #3 · Oregon Cascading
Magnificent catch!
Feb 28, 2023 at 09:12 PM
LovePG
p.1 #4 · Oregon Cascading
Paradisical!
Feb 28, 2023 at 09:36 PM
Camperjim
p.1 #5 · Oregon Cascading
That is some super smooth water contrasting with the highly textured neon green foliage!!
Mar 01, 2023 at 06:41 AM
J. Pow
p.1 #6 · Oregon Cascading
So amazing!
Joel
Mar 01, 2023 at 07:38 AM
saaketham
p.1 #7 · Oregon Cascading
Beautiful
Mar 01, 2023 at 09:13 AM
Mark Metternich
p.1 #8 · Oregon Cascading
Huge thank you. Sorry I’m traveling right now and I’ll try to get back to the comments later. But yes, Oregon is paradisicle!
LovePG wrote:
Paradisical!
Mar 04, 2023 at 08:58 PM
pjmsj21
p.1 #9 · Oregon Cascading
Mark,
Not that it really matters but curious as to what prompted you to move to the S1R?
Also do any of your videos walk one through the post processing similar to what you described above?
Thanks
Pat
Mar 08, 2023 at 12:25 PM
Mark Metternich
p.1 #10 · Oregon Cascading
Hi Pat.
Thank you so much for the compliment.
Yes, I’m going to have a full course, A-to-Z video tutorial that has taken me 4 years to make. It will be coming out in the next couple weeks. It is going to be at least six hours long showing full processing from beginning to end and more. This is going to change everything for a lot of people.
Because people have been demanding it so much I decided I will put out a rougher version that has a little less of the visual aids in it in the next two weeks. Then, when it gets fully revised and finessed, anyone who has purchased it can get the revised version for free!
All you have to do is go to my website and join the newsletter to find out about its release. Plus I send out lots of valuable freebies on my newsletter anyway. 😁
Here is the answer to the Panasonic Lumix S1R:
Having the extremely unique and incredibly privileged full time job for the last 15 or so, years, doing the post processing for world class print enlargement for some of the highest end nature and landscape photography galleries in the world, nationally and internationally, as well as doing many others work for exhibitions or individual print, and things like that, working on literally thousands of files from every conceivable camera and lens combination. Everything from the newest Phase One, or 8 x 10 film, or Hasselblad, of course, Sony, Nikon, Canon, Fuji, and everything else… Also being a constant tester of all these systems, as well as pushing the limitations of all of these systems, in terms of size, and sheer high resolution detail print quality. Getting to test all the software all the time. And constantly pioneering and pushing the bleeding edge of enlargement quality techniques to new levels unheard of before...
Literally, I have found that the Panasonic Lumix S1R, along with the Leica SL2, both cameras (not having overdone megapixels) and precisely at 47, with superior pixel shifting technology, are able to produce files that match, and even BEAT the best of every system I have tested.
When you put something like the like a Leica 90mm, or 75mm or 50mm APO, Summicron or a 55mm Zeiss Otis, or several other highest rated lenses for sharpness, on either of these two camera systems, and you use the superior 187 megapixel HD mode, the photos (and especially how they can be pushed and handled) are absolutely mind-boggling! We are literally setting print quality detail world records with these systems.
These are my two highest rated camera systems in the world at the moment, even above the best of medium format.
Given $1 million to buy any system in the world, this is still what I would be shooting with. The only difference is that I would own all of the sharpest lenses in the world.
I know these kinds of statements will cause controversy, but I only know one other human being that does what I do for a living at the level that I do it, pushing all kinds of files to their absolute edge. This other person could afford any camera system, and still has them on the shelf, collecting dust, as they are also using the same system for their highest most critical detailed work.
I hope it helps.
pjmsj21 wrote:
Mark,
Thanks
Pat
Edited on Mar 08, 2023 at 01:17 PM · View previous versions
Mar 08, 2023 at 01:08 PM
Ross Martin
p.1 #11 · Oregon Cascading
Mark, the sense of flow and movement you achieved by your choice of composition is fantastic! Also enjoyed reading about your workflow. I may someday take your workshop. But I worry about adding complexity to my processing life, as I have come to love the intuitive simple workflow (for my brain) in Lightroom, and I’ve always hated how Photoshop makes me feel stupid lol!
Congrats on another beauty 👍🏼
Mar 08, 2023 at 01:16 PM
Mark Metternich
p.1 #12 · Oregon Cascading
Thank you very much Ross.
HUGE leaps in raw file quality and a massive reduction of overall labor can both be achieved very simply by starting out with a linear profile in Camera Raw, and the critically using individual curve masks to customize the first four, absolutely most essential adjustments that any Raw file goes through.
That would be easy and the most bang for your buck. If you don’t want to continue to develop your skills in Photoshop.
If that’s all you did, you could hit “done”
and it would show up in Lightroom WITH the Most important custom adjustments built-in, and you wouldn’t have to do anything else. The difference would be a file that is so much closer to how it should look or how you want it to look. And not only that, the sliders in Lightroom will work unbelievably better in every way.
Just food for thought.
All the best to you and yours.
Mar 08, 2023 at 01:25 PM
hm2008
p.1 #13 · Oregon Cascading
Beautiful waterfall, it's a massive impact to my eyes!
Mar 15, 2023 at 06:06 PM
roadapple
p.1 #14 · Oregon Cascading
Stunning work !
Mar 15, 2023 at 06:34 PM
Jim Dockery
p.1 #15 · Oregon Cascading
Gorgeous.
Mar 16, 2023 at 09:57 AM
DivineFocus
p.1 #16 · Oregon Cascading
That's downright ethereal. Well done.
Mar 16, 2023 at 01:48 PM
Mark Metternich
p.1 #17 · Oregon Cascading
Huge thank you Sunny. This photo gets me jacked up because in a few weeks, I go to Oregon to lead my The Ultimate Pacific Northwest Workshop.” And I get to see my family, friends and community, I haven’t seen for a long time. Aside from Florida, this (Oregon/Pacific Northwest) is my favorite place to photograph in the world!
Sunny Sra wrote:
Mark,
Freaking awesome!
Apr 08, 2023 at 12:12 PM
brianbeatty
p.1 #18 · Oregon Cascading
Beautiful image Mark! Really captures the dense forest feel of the PNW well
Apr 08, 2023 at 03:39 PM
Mark Metternich
p.1 #19 · Oregon Cascading
Huge thank you! I'm heading here in a week or so for my group. I can not wait to see my PNW again!
May 03, 2023 at 01:09 PM
Jim Dockery
p.1 #20 · Oregon Cascading
Beautiful.
May 03, 2023 at 06:56 PM
