1       2       3       4              end
Archive 2023 · Are the A7R5 improvements worth it to you?
j4nu
p.5 #1 · Are the A7R5 improvements worth it to you?
chiron wrote:
Yes, I think that is why the help guide pegs anti-flicker to fluorescent lights, because they flicker with the grid but LEDs do not and vary, so they get the variable shutter. It seems to me more likely that the variable shutter would work for fluorescents than that the anti-flicker would work for LEDs.
Agreed, but LEDs can also flicker at 50/60 hz which would make antiflicker work on them...
Jan 16, 2023 at 06:59 PM
GMPhotography
p.5 #2 · Are the A7R5 improvements worth it to you?
Thats what I wanted to hear and maybe that helped me on that gig as I had it on
Jan 16, 2023 at 07:03 PM
chiron
p.5 #3 · Are the A7R5 improvements worth it to you?
Here is Mark Galer on how he thinks about and chooses to use anti-flicker in setting up his A1:
"Anti-flicker Shoot. and Variable Shutter:
These options provide me with the ability to remove banding from my images. This banding (visible stripes running across my image) could be a result of photographing with low-frequency light sources, such as Fluorescent Lights (Anti-flicker shoot), or high-frequency LED lights (Variable Shutter). I do not leave Anti-flicker permanently switched on as this will lower the resolution of the Finder."
Here is the source:
https://alphauniverse.sony-asia.com/learn/reviews/alpha-1-setup-mark-galer
Jan 16, 2023 at 08:17 PM
j4nu
p.5 #4 · Are the A7R5 improvements worth it to you?
Here is the source:
Yeah, I think this proves we are all in agreement as he mentions the frequency of the light source as well.
Jan 16, 2023 at 08:54 PM
Younjulius
p.5 #5 · Are the A7R5 improvements worth it to you?
I’ve read the white balance was also improved a lot. Is it true in tne case between M4 and R5? Or, only from R4?
Jan 29, 2023 at 06:04 PM
1       2       3       4              end
1       2       3       4              end
