fredmiranda.com Login
This topic is in the 2020 archive. You can read it and like its posts here. It is read only.
Archive 2020On Golden Pond
bobbytan
p.1 #1On Golden Pond
I am relatively new to bird photography but this particular pond attracts ibises at this time of year. They feed on crayfish in the pond - I had no idea that there's crayfish in the pond until Bob Greenberg (Bob657) mentioned it. Anyway, the ibises will fly in at dawn with clockwork precision (6:45am) while it's still dark (so I have no choice but to pull out the flash) and leave shortly after sunrise. Eat and leave ... how very rude! A warm sunrise on a cloudless morning would turn a section of the pond into a golden pond. So with a bit of luck, an ibis or snowy egret or GBH or duck would stroll into that section of the pond which makes for a great environmental image. This was shot over the last couple of days.
3
4
5
6
7
8
9
10
11
12
Dec 27, 2020 at 08:30 AM
Details
p.1 #2On Golden Pond
10 has that pretty light and nicely balanced flash creating a lovely image. Try some -EV on your flash once the sun comes up to avoid a flat image as seen in 11.
Dec 27, 2020 at 08:39 AM
bobbytan
Details
p.1 #3On Golden Pond
Thanks Morris! No flash was used on #11. It's just very hard to shoot the snowy egret without blowing out some detail. I should have spot-metered the bird instead of using center-weighted metering or partial metering as Canon calls it.
Dec 27, 2020 at 09:08 AM
Ronny Olsson
Details
p.1 #4On Golden Pond
Great set Bobby !
Ronny //
Dec 27, 2020 at 09:36 AM
juankgigo
Details
p.1 #5On Golden Pond
Nice set of images Bobby, one question: did you use flash for the ibises?
Dec 27, 2020 at 09:42 AM
Details
p.1 #6On Golden Pond
morris wrote10 has that pretty light and nicely balanced flash creating a lovely image. Try some -EV on your flash once the sun comes up to avoid a flat image as seen in 11.
Even if you use spot metering, you will find the exposure is wrong as the camera will try and make white gray. Find a favorite metering mode and use exposure compensation. If you have time you can use the camera's blinking highlight warning to adjust the exposure to avoid clipping the highlights.
Dec 27, 2020 at 10:04 AM
AGeoJO
Details
p.1 #7On Golden Pond
An impressive and enjoyable set of images, Bobby!
Joshua
Dec 27, 2020 at 10:15 AM
nandadevieast
Details
p.1 #8On Golden Pond
Nice shots. I think 1 to 5 are in a different league than the rest.
Dec 27, 2020 at 10:30 AM
keepclicking
Details
p.1 #9On Golden Pond
Superb set Bobby 🙏
Dec 27, 2020 at 11:26 AM
louie champan
Details
p.1 #10On Golden Pond
Amazing series, enjoyed each one of them Bobby.
bobbytan
Details
p.1 #11On Golden Pond
Thank you, Ronny!
Ronny Olsson wrote:
Great set Bobby !
Ronny //
Dec 27, 2020 at 11:46 AM
bobbytan
Details
p.1 #12On Golden Pond
Thank you, Juan! For the ibis shots, yes, I did use the flash (except for #5 - the flash probably fired in the first couple of sequential shots before it stopped to recharge - so this frame didn't receive any light from the flash) as they were mostly shot in very low dawn light.
Edited on Dec 27, 2020 at 12:04 PM · View previous versions
Dec 27, 2020 at 11:48 AM
bobbytan
Details
p.1 #13On Golden Pond
Thanks Joshua!
Joshua
Dec 27, 2020 at 11:49 AM
bobbytan
Details
p.1 #14On Golden Pond
Thank you, Anurag!
Dec 27, 2020 at 11:50 AM
bobbytan
Details
p.1 #15On Golden Pond
Thanks! 🙏
keepclicking wrote:
Superb set Bobby 🙏
Dec 27, 2020 at 11:51 AM
bobbytan
Details
p.1 #16On Golden Pond
Thank you, Louie!
Dec 27, 2020 at 11:52 AM
bobbytan
Details
p.1 #17On Golden Pond
Thank you, Joshua!
Joshua
Dec 27, 2020 at 11:53 AM
bobbytan
Details
p.1 #18On Golden Pond
True ... but it means that the whites will be under-exposed by a couple a couple of stops. I would usually playback the shot to check - so if I see that it's under-exposed I can always use the EC to compensate. I should have checked the histogram - always forget to do that!
morris wrote:
bobbytan wroteThanks Morris! No flash was used on #11. It's just very hard to shoot the snowy egret without blowing out some detail. I should have spot-metered the bird instead of using center-weighted metering or partial metering as Canon calls it.
Dec 27, 2020 at 11:57 AM
Bobg657
Details
p.1 #19On Golden Pond
I'm glad you went Bobby, just beautiful light on these!
Bob
Dec 27, 2020 at 12:01 PM
bobbytan
Details
p.1 #20On Golden Pond
Yes, the warm morning light is gorgeous on some sections of the pond ... but most of the ibises had l already left by then, although a handful may stick around for a bit longer.
Bob
Dec 27, 2020 at 12:06 PM
FM ForumsNature & WildlifeJoin Upload & Sell
