Archive 2020 · Duck's eye view...
arbitrage
p.1 #1 · Duck's eye view...
Once you get used to shooting at water level via the flip screen it is hard to ever go back to even a low crouching position like I used to do. Sometimes you do get some interesting water patterns from a crouched position but most of the time I prefer the super soft foregrounds and backgrounds that having the camera a duck eye level provides.
3
4
5
6
7
8
Apr 12, 2020 at 07:50 AM
KCollett
p.1 #2 · Duck's eye view...
Quality images, Geoff. #3 and #7 are my faves.
Apr 12, 2020 at 08:01 AM
sum1sgrampa
p.1 #3 · Duck's eye view...
Just unreal. Your work never ceases to amaze.
Apr 12, 2020 at 08:54 AM
Dragonfire
p.1 #4 · Duck's eye view...
Very nice That's Little Ceasars thin crust pizza low.
Apr 12, 2020 at 09:14 AM
AGeoJO
p.1 #5 · Duck's eye view...
Wonderful and impressive images, Geoff! The low angle makes the difference and a huge one at that. I am hooked that way, too but it is not always feasible. I remembered a case recently when I hurried to a spot to capture an on-going action but I had to settle with an elevated bank of the water body... .
Joshua
Apr 12, 2020 at 09:23 AM
p.1 #6 · Duck's eye view...
3, 4, 6 and 7 are my favorites Geoff. I agree the lower the angle the chance of a very engaging image increases. I find it harder to track and compose the way you are doing this yet still do it sometimes for the rewarding results.
Apr 12, 2020 at 09:27 AM
kdacharya
p.1 #7 · Duck's eye view...
lovely images, Geoff. seems to me that the bokeh and IQ are significantly better with the 7RM4 + 600mm as compared to the A9 a+200-600, or is it just me?
Apr 12, 2020 at 09:48 AM
louie champan
p.1 #8 · Duck's eye view...
The overall IQ of these images is incredible and the low shot angle adds significantly to the image.
Apr 12, 2020 at 09:49 AM
p.1 #9 · Duck's eye view...
Stunning, each and everyone of them.
Apr 12, 2020 at 10:21 AM
Migara
p.1 #10 · Duck's eye view...
Apr 12, 2020 at 10:25 AM
psharvic
p.1 #11 · Duck's eye view...
Great work, Geoff. My back hurts even of thinking of ways to get this low
Apr 12, 2020 at 11:11 AM
arbitrage
p.1 #12 · Duck's eye view...
Thanks Ken
Thanks
Thanks Frank
Thanks Joshua...yep...if the action happens you sometimes can't be this low or aren't ready while being this low. It is certainly harder to follow something quickly when deployed on the ground with the flip screen
Joshua
Thanks Morris it is certainly harder to track and pan. I make use of the Sony's tracking so it does that and I just try to concentrate on the composition.
Apr 12, 2020 at 06:17 PM
surfnron
p.1 #13 · Duck's eye view...
Another great set Geoff ~ Ron
Apr 13, 2020 at 07:53 AM
arbitrage
p.1 #14 · Duck's eye view...
Migara wrote:
Thanks for the comments.
Apr 14, 2020 at 07:43 AM
arbitrage
p.1 #15 · Duck's eye view...
One has to expect that having 61MPs vs 24MPs and having a $13K prime lens vs a $2K zoom lens (with a 1.4TC on it in these two images) is going to favour the 7RM4 over the A9II images in this thread.
But I will also add a few qualifiers in regards to these specific images. The two A9II/200-600 images do have the 1.4TC on them, they were shot handheld from kayak where as the RIV/600 images where shot from on shore, camera/lens on the ground. Therefore the only A9 file that you can even see the bokeh (as the first shot really doesn't have any defined bokeh to even look at) is the Wood duck pair. That shot has the shoreline tree line background maybe about 30 feet behind the perch in comparison to the A7RIV shots that basically have a background about 0.5km-1km away and getting so low (probably 2 feet lower than in the kayak) helps that even more.
Bottom line, these images are not a good sample to compare between. A more fair comparison would be to check some of my older images in the Sony 200-600 thread, shot with the A9 or A9II and shot in a similar way to the A7RIV shots (ie ducks from shoreline with camera on the ground). Or alternatively checking out some A9/A9II shots with the 600GM in the 600GM image thread. Those examples may give you a better idea of the differences. Ideally viewing the images on my Flickr page would be even better as IQ on Flickr is a lot better than the way images are displayed on FM via the FM Upload feature (especially if viewing on a 4K or 5K display). Also if viewed on Flickr you can click on View All Sizes (found under the download link in lower right of each image) and view up to 6K resolution if available. If 6K is not available when you check View All Sizes then the largest size available is equal to the final crop of the RAW file to give you an idea of the MPs after cropping and that should also help do a better comparison between different camera/lens combos.
Apr 14, 2020 at 07:56 AM
dallvr
p.1 #16 · Duck's eye view...
These lovely images are proof of your low angle concept! They are much more intimate than photos shot from higher up. Great set.
Apr 14, 2020 at 09:19 AM
kdacharya
p.1 #17 · Duck's eye view...
...Show more →
Good points, Geoff. Please PM me your Flickr link. Many thanks.
Apr 14, 2020 at 09:53 AM
hm2008
p.1 #18 · Duck's eye view...
Crystal clear! Great shot.
Apr 14, 2020 at 11:03 AM
arbitrage
p.1 #19 · Duck's eye view...
There is a Flickr Icon below my Avatar/Stats that will take you there.
Apr 14, 2020 at 01:21 PM
kdacharya
p.1 #20 · Duck's eye view...
got it thanks.
Apr 14, 2020 at 03:21 PM
