WA Rules ยท Current entries
Archive 2018 · #817 Collision
nnitzky
p.1 #1 · #817 Collision
When drops collide
Jun 03, 2018 at 12:53 AM
beavens
p.1 #2 · #817 Collision
Great shot!
Jeff
Jun 04, 2018 at 07:22 AM
nnitzky
p.1 #3 · #817 Collision
Thanks Jeff!
I like the color progression in yours. I haven't played around with adding color to the liquid yet. Will have to try that soon...
Nathan
Jun 04, 2018 at 09:39 PM
beavens
p.1 #4 · #817 Collision
nnitzky wrote:
Thanks Jeff!
Nathan
Thanks Nathan, just another thing to play around with and make a mess!
Good luck with voting!
Jeff
.edit Mind going into some detail as to how you caused the 'collision'?
Jun 05, 2018 at 01:40 PM
nnitzky
p.1 #5 · #817 Collision
Jeff-
The collision is a matter of timing between the first drop and the second drop. The second drop needs to be falling at the precise moment that the first drop is rising back out of the pool so that they collide at or near the apogee of the first drop's rise. Then the flash of course must be timed to coincide with the collision. This is made very easy with the MIOPS Splash device. The system is controlled via bluetooth from a smartphone or tablet. One simply needs to specify the size of droplets (in milliseconds of water flow), the time between the droplets being released (in milliseconds) and the time delay before the flash is fired (in milliseconds). You just need to experiment with the timing until a suitable combination is found. Making minuscule changes in timing can dramatically change the dynamics of the collisions. If you want more details I'd be happy to elaborate further.
Nathan
Jun 05, 2018 at 11:36 PM
beavens
p.1 #6 · #817 Collision
nnitzky wrote:
Jeff-
Am I the only person without a cool drop machine?! Thanks a lot for the info, Nathan. I googled the MIOPS device and will look more into it.
The 'flower' effect is really neat!
Jeff
Jun 06, 2018 at 07:02 AM
fbgeffs
p.1 #7 · #817 Collision
Be sure to research the MIOPS device before purchasing. Many have found it inconsistent and in need of some fine tuning.
Jun 07, 2018 at 12:37 PM
p.1 #8 · #817 Collision
Amazing!
Jun 08, 2018 at 11:21 AM
