fredmiranda.com Login
This topic is in the 2016 archive. You can read it and like its posts here. It is read only.
Archive 2016White Pocket Symmetry
Kane Engelbert
p.1 #1White Pocket Symmetry
Often photographed scene at White Pocket with my own spin. I used a (under appreciated landscape lens) 17mm tilt shift and stitched 2.5 images to create this very wide scene with very little distortion. I'm beginning to prefer this technique in going very wide vs a traditional wide angle. It has its payoffs, the distortion control, beneficial f-stop control with top image and bottom image can be different f-stops, and in the end these images can be printed huge.
Thoughts?
Canon 5dsr
17mm tse
top half at f10 bottom half at f16
May 30, 2016 at 06:18 PM
DaleBerlin
Details
p.1 #2White Pocket Symmetry
Wow stunning image, you da man. I totally agree with your pano technique. I do it because I am cheap and don't want to buy a wider lens . The bottom appears as if a slight gradient was applied (which I really like). Is that the result of stitching f10 with f16? Well done!
May 30, 2016 at 06:42 PM
psharvic
Details
p.1 #3White Pocket Symmetry
Technique seemed to work very well. Did you also refocus?
May 30, 2016 at 06:44 PM
sachman
Details
p.1 #4White Pocket Symmetry
Wow love this perspective! Great technique.
May 30, 2016 at 06:59 PM
Kane Engelbert
Details
p.1 #5White Pocket Symmetry
No the result of the Vignetting is hand applied. Thanks for the comment.
May 30, 2016 at 08:18 PM
Kane Engelbert
Details
p.1 #6White Pocket Symmetry
Kept it simple, and in these kinds of scenes, no need to adjust focus on bottom image. Let the DOF do the work.
May 30, 2016 at 08:20 PM
Jeffrey
Details
p.1 #7White Pocket Symmetry
Nice image, Kane. Seems that you only needed to refocus for the foreground if you focused and shot the distance first. Changing aperture puts the subject in the 'perceived focus range" of the aperture setting rather than manually putting the actual focal plane where you want it, The results will be nearly identical at smaller sizes, but re-focusing has it's advantages.
May 30, 2016 at 09:15 PM
Scott Kroeker
Details
p.1 #8White Pocket Symmetry
Stunning image!
May 30, 2016 at 10:00 PM
AmbientMike
[X]
Details
p.1 #9White Pocket Symmetry
Wow! So you're stitching horizontals together?
May 30, 2016 at 10:17 PM
dbehrens
Details
p.1 #10White Pocket Symmetry
Lovely capture with great atmospherics - and as far as stitching vs a FF UWA lens I see the merits of both. BUT, if you want to capture a scene in a way similar to a large format camera then stitching is the only way for a 35mm camera. I have often struggle with how to capture the grandeur of wide vistas such as the Grand Canyon and have concluded stitching is the best way. Dave
May 30, 2016 at 11:28 PM
JimFox
Details
p.1 #11White Pocket Symmetry
Hi Kane,
An interesting process you chose here. The end result is a very cool shot indeed, and I really like the way it looks.
Jim
May 31, 2016 at 03:03 AM
thw2
Details
p.1 #12White Pocket Symmetry
A simple image but the composition and colors rock!
May 31, 2016 at 03:28 AM
Gary Clennan
Details
p.1 #13White Pocket Symmetry
Very nice and the image is perfectly processed.
May 31, 2016 at 08:16 AM
ArturS
Details
p.1 #14White Pocket Symmetry
Great photo Kane. I like the effect of tilt/shift sense. Using wide lens has its advantages but recently I'm going away a little from super wide lens shots. Tilt/shift works perfectly here.
May 31, 2016 at 06:30 PM
OregonSun
Details
p.1 #15White Pocket Symmetry
Really nice details, colors and light in this one. I'm also a big fan of using panoramas to get a more realistic perspective. This one with the 17 still has the visible stretching of the corners, but it's not nearly as in your face as 11-12. I go with 24 or 40 (on a crop sensor) when I do these. Lately I've just been grabbing my Pentax 67 though, which achieves a similar effect due to the huge 'sensor'.
Heron
May 31, 2016 at 11:31 PM
Tuan Le
Details
p.1 #16White Pocket Symmetry
Whichever way you got the image, the result is great. Wonderful comp and conditions.
May 31, 2016 at 11:38 PM
lionking
Details
p.1 #17White Pocket Symmetry
Well worth the investment in both: the equipment and skill,
Great work!
Andrey
Jun 01, 2016 at 09:52 AM
MJKoski
Details
p.1 #18White Pocket Symmetry
Kane, I used the exact same technique with my 17mm TS-E. It works very well indeed when printing large. Also works sideways.
I'm a sucker for stone formations and this spot keeps working for me no matter how many times others may have photographed it. You captured the subject in great light. The TS-E is also wide enough that it creates dramatic near-far effect even with corrected perspective.
Jun 01, 2016 at 10:42 AM
Anand Pichumani
Details
p.1 #19White Pocket Symmetry
Nice! another wonderful usage for 17 ts-e. I too have started loving this lens as brings loads of opportunities for near far scenes. Have you tried using tilt for these shots?
Jun 01, 2016 at 12:26 PM
Brad Williams
Details
p.1 #20White Pocket Symmetry
Beautiful photo Kane! Really like how its composed and you got some beautiful light. Nice work.
Jun 22, 2016 at 01:55 PM
FM ForumsLandscape PhotographyJoin Upload & Sell
