Archive 2016 · Hummingbird bathing setup
Imagemaster
p.1 #1 · Hummingbird bathing setup
Posted these shots in 2012, but someone on the Canon forum requested them. Since that is now an archived thread and the images deleted, I have to re-post them.
Like creating a set for a movie, it does not matter what the overall look is, only what your camera will capture.
EDIT: I should add that it is best to have the bathing area located 3-4 feet above the ground. Not only does this allow an easier shooting height, but makes it less likely that a cat can easily capture a hummer. It is also desirable to have some shrubbery located directly above. This makes the hummers feel more secure from attacks by flying predators and provides a nearby perch to use before and after bathing.
Also, their preferred depth of water for bathing is only 1/4 - 1/2 inch deep. If the water is deeper, try placing flat rocks in the water that are just slightly under the surface.
jjoejr wrote:
Imagemaster Wrote: and many requested that I provide info on how to set up a bathing area for hummers, which I did.
I must have missed this. Anyone have a link to this please?
Edited on May 29, 2016 at 11:59 PM · View previous versions
May 29, 2016 at 02:56 PM
thomashammer78
p.1 #2 · Hummingbird bathing setup
AWESOME
what lens was this shot with? (the final shots that is)
May 29, 2016 at 02:59 PM
Imagemaster
p.1 #3 · Hummingbird bathing setup
Thanks. 300 f2.8 on 1D4.
May 29, 2016 at 03:04 PM
Kathy White
p.1 #4 · Hummingbird bathing setup
Thank you so much for posting this Tony. What a fabulous idea.
May 29, 2016 at 03:47 PM
jjoejr
p.1 #5 · Hummingbird bathing setup
I've never seen this setup. As a fall migration hummer photographer it adds another dimension to my setups. No doubt it would work on my small yard birds also. Images are flawless. Thanx for posting.
May 29, 2016 at 06:11 PM
surfnron
p.1 #6 · Hummingbird bathing setup
I'm glad you reposted these Tony ~ Ron
May 29, 2016 at 06:52 PM
tkchen
p.1 #7 · Hummingbird bathing setup
Thanks for sharing. This is so cool. Lovely photos.
May 29, 2016 at 07:39 PM
Lilki
p.1 #8 · Hummingbird bathing setup
Wow, great setup!
May 29, 2016 at 08:53 PM
canon.eos30d
p.1 #9 · Hummingbird bathing setup
Superb shot and thanks very much for detail setup, Tony.
-Tam
May 30, 2016 at 01:00 AM
erielake
p.1 #10 · Hummingbird bathing setup
cool set-up and captures
May 30, 2016 at 06:32 AM
KCollett
p.1 #11 · Hummingbird bathing setup
Very cool, even in replay mode. I can duplicate the set up, but I'm a touch short on hummers. There is always a catch.
May 30, 2016 at 07:27 AM
hotrodjohn
p.1 #12 · Hummingbird bathing setup
May 30, 2016 at 10:27 AM
surfnron
p.1 #13 · Hummingbird bathing setup
You could try using hot water in your hummer spa Ken ~ Ron
May 30, 2016 at 02:15 PM
pjbuehner
p.1 #14 · Hummingbird bathing setup
Fantastic!!
May 30, 2016 at 02:35 PM
Chris Schlaf
p.1 #15 · Hummingbird bathing setup
Very nice of you to share this Tony
Great info and images
Thank you
Chris
May 30, 2016 at 03:07 PM
mikedec
p.1 #16 · Hummingbird bathing setup
Thanks Tony for reposting this.
May 30, 2016 at 03:56 PM
jaylee73
p.1 #17 · Hummingbird bathing setup
Nice set up Tony. Thank you for sharing.
Jason
May 30, 2016 at 03:57 PM
Methodical
p.1 #18 · Hummingbird bathing setup
Nice
Jun 01, 2016 at 02:45 PM
knov87
p.1 #19 · Hummingbird bathing setup
Tag and save. What a wonderful idea! TFS
Jun 01, 2016 at 05:20 PM
13867
p.1 #20 · Hummingbird bathing setup
Awesome Tony!
CB
Jun 01, 2016 at 05:50 PM
