Archive 2015 · Fix for POS Nikon 200-500 plastic hood
trenchmonkey
p.1 #1 · Fix for POS Nikon 200-500 plastic hood
Horrible hood no more, folks. For ~$25 get yourself a 95mm to 105mm step up ring
and a 105mm metal hood off the 'Bay. Added bonus: Cir Pol betwixt the two allows
for rotation by simply turning da hood. Consider this a public service announcement.
(I leave my hoods in shooting position 24/7/365 and forgo any lens caps.
If this makes you nervous, kindly disregard my suggestions)
I'll post a pic after awhile...for those who require visual stimulation.
Nov 15, 2015 at 07:50 AM
Steve Perry
p.1 #2 · Fix for POS Nikon 200-500 plastic hood
I have a 200-500 coming this week - I didn't know the hood was sucky, but this is good to know. Thanks!!
Nov 15, 2015 at 08:58 AM
RoyC
p.1 #3 · Fix for POS Nikon 200-500 plastic hood
Nervous, no but it makes for a real long lens bag when you are toting a 800 f5.6 lens and adding an eight inch long hood to it.
Nov 15, 2015 at 09:42 AM
Chris Court
p.1 #4 · Fix for POS Nikon 200-500 plastic hood
Not a problem most of us have…
C
Nov 15, 2015 at 10:07 AM
trenchmonkey
p.1 #5 · Fix for POS Nikon 200-500 plastic hood
Pretty sure I'm referring to the 200-500 and a paltry 3"
If I had an 800 I doubt I'd be hittin' this thread.
My 200 f2/300 f2.8's store well, my long zooms are
only "long" when aroused...cough, er extended.
^ thanks, Chris
Edited on Nov 15, 2015 at 10:10 AM · View previous versions
Nov 15, 2015 at 10:08 AM
rick_reno
p.1 #6 · Fix for POS Nikon 200-500 plastic hood
Nice fix Will.
ckcarr
p.1 #7 · Fix for POS Nikon 200-500 plastic hood
Isn't that HB-71 bayonet hood essentially just as crappy as the HB-65 bayonet hood that comes with the 80-400mm lens?
http://static.bhphoto.com/images/images500x500/1438671107000_1175270.jpg
Can be yours for only $54.95
http://static.bhphoto.com/images/images500x500/1363903514000_944769.jpg
Can be yours for only $49.00
Nov 15, 2015 at 10:24 AM
trenchmonkey
p.1 #8 · Fix for POS Nikon 200-500 plastic hood
Yeah, I don't use that POS either. Nikon's out of their mind on plastic pricing.
Might want to hire someone to design decent tripod collars. Just a thought.
Nov 15, 2015 at 03:35 PM
Ektar25
p.1 #9 · Fix for POS Nikon 200-500 plastic hood
Not sure I want a hood of that size attached to the filter threads (vs) the outer rim of the lens per the Nikon included "POS". The 200-500mm threads are plastic, one significant bump could crack the front ring of the lens and leave you with an expensive repair. Any other options?
Nov 15, 2015 at 04:18 PM
sjms
p.1 #10 · Fix for POS Nikon 200-500 plastic hood
I guess they made up for those on their DX 16-80. that about the best I've seen from them
Nov 15, 2015 at 04:41 PM
EB-1
p.1 #11 · Fix for POS Nikon 200-500 plastic hood
I'd not call that a fix, but a workaround.
The drawback would be the total length with the hood, depending on the bag/backpack. I'd never try to travel with a 600/4 or 200-400/4 and hood in shooting position.
Nov 15, 2015 at 06:29 PM
RoyC
p.1 #12 · Fix for POS Nikon 200-500 plastic hood
Nikon does a good job on tripod collars for lens that come with a carbon fiber lens hood.
Nov 16, 2015 at 09:29 AM
elkhornsun
p.1 #13 · Fix for POS Nikon 200-500 plastic hood
I have the 80-400mm VR II, 500mm f4, and the 200-500mm and of the three the best lens hood is the one provided with the 200-500mm lens. It is a thicker plastic and much less likely to break or crack as with the hoods on the other two lenses, and replacement hoods for these are very expensive. The 200-500mm lens hood is the only one where I do not have to be very careful so as not to have it crack.
Out in the field I usually position myself so the sun is not in front of me and my subjects are lit from the front so I don't mount the hood off the lens I am using and leave it in the backpack.
Nov 17, 2015 at 03:46 PM
rw11
p.1 #14 · Fix for POS Nikon 200-500 plastic hood
I still like my old rubber extensible lens hoods - only to be found for smaller lenses tho
Nov 17, 2015 at 03:49 PM
gfinlayson
p.1 #15 · Fix for POS Nikon 200-500 plastic hood
Hmmm, wonder if that'll work on my 120-300 Sigster? Can't use the hood with a CPL. My only complaint about an otherwise stellar lens.
Nov 17, 2015 at 05:43 PM
trenchmonkey
p.1 #16 · Fix for POS Nikon 200-500 plastic hood
Yup! I kept the metal replacement hood when I sold my 120-300, Graeme.
Nov 17, 2015 at 05:56 PM
gfinlayson
p.1 #17 · Fix for POS Nikon 200-500 plastic hood
Thanks, Will! Order placed...
Nov 17, 2015 at 06:11 PM
davidnholtjr
p.1 #18 · Fix for POS Nikon 200-500 plastic hood
What's wrong with the hood? Never had a problem with mine.
Nov 19, 2015 at 07:54 PM
