This is pretty nice, though I do wish the foreground was a little brighter. As for doing a 5 min exposure with the IR Remote, most remotes like that will have a mode where you hold the button down for 3 seconds and then it locks in the shutter until you press it again, you should check that as then you could have done a 5 min exposure on Bulb mode. Otherwise, you just need a simple $20 wired remote that you can lock in.
How did you do Median stacking on the sky? With the movement of the stars I figured Median stacking would not work as the stars would streak.
Jim
