Archive 2015 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
MissDiagnosis
p.1 #1 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
I know this has been debated time and time again, but which would you choose and if you have samples, please post.
Edited on May 29, 2015 at 03:51 PM · View previous versions
May 29, 2015 at 08:03 AM
AmbientMike
[X]
p.1 #2 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
Never used either, but 24 is significantly wider, f/2.8 significantly faster. Image stabilization is great to have, but may require several shots in my experience with Canon IS.
Say what you will about Ken, but I thought this had a lot of info
http://kenrockwell.com/nikon/24-85mm-vr.htm
May 29, 2015 at 02:00 PM
AmbientMike
[X]
p.1 #3 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
Aps or ff body? What subject matter?
May 29, 2015 at 03:12 PM
MissDiagnosis
p.1 #4 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
Thanks for the info, I read KenRockwell, and other debates..
I can't afford 24-70 f/2.8 nikon, so figured the tamron was the cheaper alternative.
This is for the d600, full frame
May 29, 2015 at 03:23 PM
myboostedgst
p.1 #5 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
I've owned the Tamron 28-75 (I'm assuming this is what you meant) for both Canon and Nikon and currently own the 24-85. The Tamron is the lens to have, no doubt about it. Focus speed is similar, IQ is better, and you get 2.8. The 24-85 is just ok. 24 is wider than 28, but no enough to be an UWA, so for me it is a horse a piece. The VR is nice, but I still feel that the IQ is only ok on the 24-85 VR. I own a D600.
May 29, 2015 at 03:47 PM
MissDiagnosis
p.1 #6 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
Thanks for the info.
There are differing opinions on the Tamron 28-75 with the built in motor..do you have any knowledge, or shouldn't matter?
Yeah, 24 vs 28 didnt seem that much to me...I cannot afford the 24-70 and figured this was a better alternative.
May 29, 2015 at 03:54 PM
az-dave
p.1 #7 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
Get the one without the BIM (Built in Motor) if you can. Im not sure about the more recent models but the early ones were slower to focus then with the body driving the lens.
YMMV
Dave
May 29, 2015 at 04:07 PM
MichGoBlue
p.1 #8 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
I have a non-BIM 28-75 and it is pretty sharp overall. I have since purchased a Nikon 24-70 though so it is more of a back-up now, though my daughter often borrows it for her D90.
I think for a D600 it would work fine. A D800 though I think would out-resolve it.
May 29, 2015 at 05:13 PM
Pack12
p.1 #9 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
I took the Tamron 28-75 on my D600 to Hawaii and it was pretty much the only lens that I used. Great lens on the D600, it was the non built in motor version. Autofocus was quick pictures turned out great. There were just a few times where 28 was not wide enough but I was happy overall with the lens. Ended up upgrading to the Tamron 24-70 just to get a bit wider.
May 29, 2015 at 05:46 PM
Two23
p.1 #10 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
Depends on what I'm using the lens for. That's the WHOLE THING--match the gear to the use. For travel and "general" photography, I'll go with the 24-85 VR. It's more compact, is a bit wider (enough so to be useful), and has VR, something I find useful for "street" shooting and etc. when using a tripod isn't practical. For wedding photography I consider f2.8 to be a "must have." An f2.8 would also give a bit narrower DoF to blur backgrounds for formal portraits, but obviously doesn't matter if you mostly are doing landscapes.
Kent in SD
May 29, 2015 at 08:15 PM
M635_Guy
p.1 #11 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
I love my 28-75: Very sharp, light and really versatile. It gives really nice color, contrast and bokeh as well.
May 30, 2015 at 10:06 AM
M635_Guy
p.1 #12 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
May 31, 2015 at 02:30 AM
davidsyd
p.1 #13 · Tamron 28-75 f/2.8 vs Nikon 24-85 VR
I been using the Tamron 28-75mm on my D700. Fine lens. sharp and nice color. Check the spec.
I think it has less distortion compare with the 24-85mm. The f2.8 definitely comes in handy at times.
May 31, 2015 at 06:17 AM
