astro-ep wrote:
That's really spectacular. I used to shoot lightning the old-fashioned way - Luck, time exposures and a bit more luck.
Which trigger device do you use? Have you tried more than one?
Thanks for sharing,
Eric
Hi Eric, thanks for the compliments. I use a device simply called "Lightning Trigger", trademarked brand (www.lightningtrigger.com). I also used a similar device that's sold on B&H Photo by AEO Photo. They both work by the same principal, detecting rapid luminosity changes in the infrared that lightning causes. It is not fool proof, as there is shutter lag that obviously plays into the fact that not every flash is captured (lightning is pretty fast!).
