debuggerus Offline Upload & Sell: Off
ricardovaste wrote:
rtester, that is brilliant! Don't know how you found it but thank you!
Okay, so the 35-80/2.8 is on it's way, it has been for a while. Just sent off the customs form yesteryday, so hopefully I'll get it in the next couple of weeks.
I'm looking at the Zuiko I have to hand. I'm if an M42 conversion is possible? (just to make it easier to switch mounts). Seeing as you need a spacer between a Minolta/M42 mount if you're doing it that way, it suggests there is a bit of room to play with... I wonder if there is enough though, as I don't want to do anything destructuve to the lens.
Anyone tried a Zuiko to M42 conversion?...Show more →
Richard,
This should be doable. I have done a few zuikos to M42 (21/3.5, 28/3.5, and 40/2) and don't recall any particular problems while doing it. All I did was replacing the OM mount with an M42 mount and adjusting infinity focus.
The only thing that was a little difficult for me was to find spare M42 mounts. I had to cut them from a few broken takumars. Do you have source to obtain M42 mounts?
Let us know how it goes. It's one of the lenses I've always wanted.
P
