RGS65 Offline Upload & Sell: Off
I totally understand the math and conversion...but
No I don't get the marketing point, and I think its a bit deceptive, because the 20mm lens is made for Pannys 4/3 format - that is its native application and its not 20mm in that use - right? So why say that?
I understand it's a great lens - but it's not 20mm equivalent and that is what I want.
35mm reference is "magical" because some of us have used it for 40+ years. We need some reference point otherwise these labels mean nothing - at least to me.
Jman13 wrote:
As ptys says, 20mm is 20mm. 35mm film/full frame sensor is not some 'magical standard format' where focal lengths are true. A 20mm lens on 4/3 has a similar AOV to a 40mm lens on full frame, which has a similar AOV to a 66mm lens on 645 medium format, which has a similar AOV to a 142mm lens on 4x5 large format, which has a similar AOV to a 284mm lens on 8x10 large format.
Which one of these is 'true'? The answer is, they're all true focal lengths, even though all of these lenses have the same angle of view on their respective formats. The crop factor does not actually change the focal length, it's simply a tool used to compare angle of view between two different formats. The crop factor of m4/3 vs APS-C is 1.25x. The Crop factor of 35mm film vs. medium format is 1.6x The crop factor of 35mm film vs 8x10 large format is 7.2x.
See the point? BTW, the Panny 20/1.7 is an outstanding lens....Show more →
