I stretched the definition of "automobile" very significantly. I'm sorry. I hope this still works.
I caught him on 5th avenue and 14th street. I caught him when stopped, but a woman blocked me, so the next second, I fired again. Thus, there is some motion blur.
"An automobile, motor car or car is a wheeled motor vehicle used for transporting passengers, which also carries its own engine or motor."
Hey, a human is a motor too!
af120835 wrote:
Nice idea. Not sure about the PP'ing though. The subject looks kind of looks "stuck on" the background. Maybe a few tweaks?
That would be a problem... I'm not very good with Post Processing. All I really did here was just add a Gaussian blur to everything but the subject. I was also going to do a yellow tint, but I ended up not liking it after "defocusing".
I guess it does look stuck in place. Perhaps I should add motion blur? Any other suggestions?
Am i right in thinking that you did a selection around the object, inverted it, and then applied the gaussian blur?
What you can try is:
As before, select around it, invert it,
then, the critical bit:
go to select> refine edge, and set the feather to a high value, > 100 at least.
Then apply the blur. It will give it a much more graduated appearance, akin to the depth of field change you'd get on a wide aperture.
Might take a few attempts, you'd have to get the feather value and blur values "right" to get the effect you want, but it's a simple case of undoing the last two steps and redoing them with different values.
Feathering is quite a useful tool that has many applications. I only learnt about it after needing to do a simple HDR on some scenery pics and have a applied it to a lot of other techniques. That's after doing photography for 5 years..... you never stop learning...
Andy...Show more →
Indeed, you never stop learning. I actually did a feather of 5, but I didn't see that it made much of a difference. I'll try it again with 100 to see.
