davidearls Offline Upload & Sell: Off
erichard wrote:
Personally, I don't think they are that similar. IMHO, on my screen, #2 dominates the other two, although the other two are very pleasing (probably pleasing enough, unless you see #2). The veins that you are seeking to capture are much more detailed in #2.
It's interesting about the blur of a and b. I suppose that's what Lightroom and PS4 actually do when you reduce color noise via the slider in the camera raw section. I wouldn't say it doesn't affect color, since if that were the case, we'd all do it without hesitation, but I'd say that if done judiciously, you don't notice color issues. I would think if you are at ISO 100 or 200 (as might be the case for a still life), you wouldn't really need that step (?). I generally don't toy with the color noise slider unless I'm high up in ISO, like 1600 and above. But maybe I'm not up to snuff on this one.
After hearing the winner, I'm now realizing that you probably didn't crop the 100mm photo to match the others, but rather moved the camera up closer to match the crop, at the initial photo session....Show more →
Richard, I'm not using CS4 or LR, still using BibblePro for RAW and CS3. So I can't comment on the noise sliders in CS4. The noise sliders in BibblePro are Noise Ninja, and they will happily remove any and or all detail to "clean up the noise." When I take the image to Lab space, it's a simple enough extra step to do the blur. I wouldn't take an image there and back for the blurring unless it were very noisy, but I like doing color contrast work in Lab, and it's a snap to sharpen there if you've taken the image into that colorspace.
While I agree the veining is more prominent from the 100, I find it "pleasingly present" in both the first and third images. To me there's a much bigger difference between there and not there than there is to more prominent/less prominent.
