Chococat Offline Upload & Sell: Off
I tired out a magnifying eyepiece at a camera store some time back. Not sure if it is the same one, but honestly it muddied the image up. It did magnify it, but by muddying it up it caused another focusing issue, and a side by side comparison showed that my eyeball focus without it was better.
Yes!!!--I second the comment that you may want to change to the brighter focusing screen. That is what I did.
MF is a matter of practice, and I improved very quickly. The only problems I ever have now with MF come when I am trying to focus very precisely with a superwide angle lens. From 28mm and up I almost never miss, even in low light, but below that level I can have problems if I am trying to focus very precisely or on a specific detail. Maybe my eyes just aren't good enough, or maybe even the brighter focus screen doesn't give me quite enough. I have noticed that the problems with focusing the superwides involve my digital camera (5d2) rather than my film body--they both have a brighter screen, but the viewfinder on the film camera is just better and bigger to begin with. So if you cannot use Live View, the place where the AF confirm adapter is most warranted is with the superwides, it is a help to me there. But even then, best not to rely on it completely--even when it tells me I have focus I take a close look and tweak it a touch or two if it seems slightly off.
Some of the chip adapters put the camera in an MF mode some in an AF mode. If it is not letting you shoot if it does not sense focus then you have one that is putting you in an AF mode. If so, just turn it until the camera senses focus, and keep the button half depressed and tweak it until you yourself are satisfied. If you keep it half depressed after it senses focus it will still let you shoot even if you adjust it. Actually there is a benefit to either adapter, because with the one that puts the camera in an AF mode, it will allow the assist beam on the flash to aid. The real problem with the one that puts you in an AF mode is that it might lock in the metering when it senses focus and not change it as you stop down--check as you are stopping down and make sure it is changing. If it isn't, then everything will be underexposed, and the adapter is pretty useless unless you are only going to shoot wide open.
