csm Offline Upload & Sell: Off
MichaelMann wrote:
That thread from naturescapes.net would have me a little spooked if I had a Z1. I was considering a Z1 too because I love the idea of the elliptical ball head - and as Gene mentioned, its a little cheaper than the M20. If I hadn't found the right reducer bushing for my M20, I think I would have been looking for an RSS BL-40, instead of the Z1.
I had a BH-40 and sold it. I bought the Markins M10 and Z1 for side by side tests, the Z1 is the one I kept. While the Z1 is "medium" in size, it performs like the larger ballheads. The BH-40 ball is not nearly as smooth and has an odd low profile design in addition to problems with the lever touching the tripod base...unacceptable in my book. I've used the Z1 with a 400 2.8 and Mk2n over the shoulder for over a mile any number of times...zero creep and strong, the smoothish action on all axis as many others here has described. The eliptical ball is unique and works as advertised. This rig is the heaviest combination you can put on any ballhead...and only less than the 600 with the same camera by a couple of ounces...and far heavier than the rig the Naturescapes person had.
If you are serious about getting a good ballhead, the ONLY way to verify that you are getting the best one is do that is to exactly what I did. Buy them and test them. Return the ones you don't like.
If you do this, and almost nobody does because it is work to do, let us know what you think. I bet I can guess the answer. IMHO, the Z1 is the best of the bunch for the medium sized ballheads, from someone that has owned and used all three.
Read this too...basically says the same things about the performance of the Z1... http://www.the-digital-picture.com/Reviews/Arca-Swiss-Monoball-Z1-Ballhead-Review.aspx
In fact, the Z1 is so strong, they don't compare it to something like a BH-40, they compare it to the big BH-55.
I don't know if this pic is helpful but it might be, on the left is the Z1...on the right is my big ballhead, and Linhof Profi III...what I normally use for the 400 (when not on the full Wimberley that is)...but I'm completely comfortable with the big rig on the Z1.
BTW, the Linhof Profi III shown on the right is quite a bit larger...somehow the perspective and distance does not really show that. It is a beautiful, big, very heavy, expensive, well machined beast. Not for travel and the strength is certainly not needed for any but the heaviest of setups.
Edited on Mar 22, 2008 at 12:27 AM
