BarnDog Offline Upload & Sell: Off
You should be able to access the login page by going to your web address / folder name / bluadmin
This is your login page. If you have a login, go right in. If you do not have this info, there will likely be a link to change your password. This should email a changed password to the email account you gave them when you signed up. If this does not work, it means there is a file in the database they set up with the wrong email address.
I am NOT telling you to GO INTO YOUR DATABASE TABLES and look for the file which contains the contact info and change it to your email address. Because if you did that there is no guarantee that you will not mess something up. Otherwise changing the email address would cause this un-advised change to work and you would get the password to get in.
This is probably NOT a good idea even if you BACK UP THE FOLDER first and possibly FTP THE ENTIRE THING to your local computer so if anything happened you could easily restore it all to original configuration.
If you did all of that foolish business and got into the configuration, you could "theoretically" just move it all into the root of your web space and be live.
I would never admit that I DID THIS EXACT THING because that might cause someone to mess up their site and I would feel bad.
