mjmyap Offline Upload & Sell: Off
Thanks for all the helpful replies. In response to Jammy, I took the UV filter off before sending it to Canon. The technician who was assigned the lens actually contacted me to tell me that he was puzzled because he couldn't find anything wrong with the lens' calibration .
Anyway, I re-tested the bad filter with the 24-105, at 24mm and 105mm wide open, with and without a filter. The test is rough and the images sizes and exposures are not very well-matched but I think the trend is clear.
http://farm3.static.flickr.com/2328/2123905956_0ee35a67d8_o.jpg
At 24mm, performance with and without a filter are very similar. At 105mm, there is perceptible degradation, but nothing as extreme as 400m on the 100-400. I also tested the 105mm setting without a filter, a second Hoya filter and the bad filter.
http://farm3.static.flickr.com/2315/2123906202_d9e5d689f1_o.jpg
In this case, the second control Hoya filter doesn't seem to degrade the image as much as the bad Hoya filter.
On the whole, I found this experience educational. Clearly, there is an interaction between filters and lenses. That is, filters have a deleterious impact on your images, but the effects are far more pronounced at longer focal lengths. I might not have noticed the impact of the bad filter on the 24-105, but its effects were very clear at 400mm.
The question of course is whether this is due to the intrinsic characteristics of my filter, or whether this is just copy variation and I happened to have gotten a bad copy.
