Here's my shot at using a long exposure for non-standard effect. I had the idea of those happy and sad masks that I often seen done in porcelain or drawn. I know the expressions aren't very good, but I'm the only model willing to put up with me Let me know what you think.
...but I have to ask, which head gets to interpret what your ear hears? Do they take it in turns? Do you get charged twice as much at the hairdressers?
Thanks Michael, I entered a couple of these before, but that was about a month ago and I completely blanked on adding the contest number - nice save.
I wasn't really trying to reproduce the masks I put up, more my memory/impression of the many such masks I've seen over the years - I just googled for some representative image so people would know what I was aiming for (i.e. not think I was crazy )
Flibble: Hope I can find a hairdresser that charges by the acreage - should make for some pretty good deals in about 10 years
Your lighting has me baffled. Your exif info shows no flash and the lighting on the faces is identical only reversed. If you had two flashes set up on opposite sides, the back of your head would also be lit.
I thought for some reason I had put the method in my original post - guess I was more tired than I thought. Basically, I used a long exposure and manually positioned the flash then fired it twice. Had to run through a few trial shots to get my head positions how I wanted them - thankfully, I got lucky and only had to do 5 or so.
Long version:
Set camera to wait 5 sec, then open shutter giving me time to sit and use all my acting ability to create a heart-rendingly sad visage.
Held white umbrella in one hand, flash in the other to give a fairly soft, but directional light off to the side and a bit behind my face.
The white walls of my apartment provided just a little bit of fill light to the opposing side of my face.
I then switched the umbrella and flash to my other hand, turned my face, and went to my happy place (all new canon L's).
Oh, and btw, the exif shows no flash if it was triggered throught the pc sync connection instead of the hot shoe which is how mine connects (can't afford all the new bells and whistles). So, the on camera flash did go off, but I had it set on 1/80 so it contributed no exposure, it just optically triggered the handheld flash which the timer had given me time to position. Then the second flash was triggered using the test button on the flash.
A for acting, A for concept, A for lighting, A for achieving the result using essentially a double exposure rather than Photoshop.
B- for thinking that we wouldn't know at a glance what you intended to parody!
Thanks for the comments Jess, and yeah... I guess you caught me out in my favourite activity - over explaining myself. A byproduct of spending my entire life in schools I suppose.
