stkhapugin Offline Upload & Sell: Off
| p.1 #1 · p.1 #1 · Leica Apo-Summicron-M 35mm vs Voigtlander APO-Lanthar | |
Since the two lenses were announced in early 2021, I was very curious to see how they compare.
We know that the 50mm APOs have a very similar image quality, the Voigtlander being marginally larger, 8 times cheaper, and having arguably better ergonomics. Many would argue the Voigt is actually the better lens optically. And all of this makes sense: the Leica lens is 8 years older and a bit smaller, putting it at a disadvantage.
The two 35mm APOs, however, are released within a month from one another. Again, the Voigtlander is larger, 8 times cheaper, but this time it can't focus as close. But was Cosina able to use these tradeoffs to build a higher optically performing lens?
Somehow, even three years later, I can't find a direct comparison between these two. So when I finally found a copy of the Leica, I decided to get both lenses, run some tests, and return the one I like less. Frankly, I was hoping the Voigtlander is going to come out on top.
I can't attach images here, so I uploaded them to Google Drive, shot at f/2 if the file name doesn't state otherwise.
For fun, I threw in a couple of images with the Ultron 35/1.7 (at f2) and the RX1R II.
What I'm seeing is: Leica has way nicer bokeh due to low optical vignetting, is sharper in the center at all distances, sharper overall, is better corrected for chromatic aberrations. The only downside I see is the noticeable pincushion distortion.
The Voigtlander has a bit more contrast and less distortion, but the bokeh has a lot of artefacts.
Curious to hear what you think! And I still have the Voigt for another day, so let me know if I should test something else before returning it.
