jcolwell Offline Upload & Sell: On
I modify my Grippers, like this:
1. cut off the Domke QR swivel (it doesn't lock, so I don't trust it), and replace it with a strong SS split ring
2. reattach the ends backwards, securing the loose-end webbing strap through the strap-pad D-rings
3. add a commercial, tuna fishing swivel and a small, screw-locking carabiner (about 1" long) to the other ends
4. attach the strap to the camera using the mini-carabiners, through small DIY webbing loops in the camera strap lugs.
In addition to making the connections more secure, this lengthens the straps a bit, so that the camera grip is at relaxed hand height (arm hanging at my side), when the camera is hanging straight down off a shoulder. I've used this setup without fails since about 2005. Often with one camera hanging off each shoulder (typically a wide-angle zoom on one, and 70-200/2.8L IS on the other, plus a 300/2.8L IS or 500/4L IS on a monopod.
 © jcolwell 2005-2024
Top: original strap ends (on 1" Gripper), bottom: modified ends (on 1 1/2" Gripper)
Closer view of modified strap ends
Gripper attached to DIY camera-strap lug loops
Schematic for camera-strap lug loop
