garyvot Offline Upload & Sell: On
mheston wrote:
Hi,
I am spreading the news about the failure of communication between Canon "Sender" (Master) flashes and Canon "Receiver" (Slave) flashes. Since around 2020 the communication between Master and Slave flashes can be broken by a public radio wave of some kind. I’m not an EE, so I can’t tell you what the source of the problem is, but I can tell you that I have tested equipment all over the greater Seattle area, and about 80% of the time the Slaves disconnect from the Master in under 20 minutes of being turned on. The shortest time to disconnect happens in 60 seconds with most disconnects occuring in 8-12 minutes. I’ve only tested this in the greater Seattle area, but I suspect that if you are in a major urban area you will experience this failure.
I’ve tested this with Canon 600EX RTs as well as a new R3, RL-5 flash, and ST-E10 transmitter, so it’s happening to the latest Canon equipment.
You can read about what I’ve tested here: https://hestonphoto.com/info/canon-flash-failure-01.html
Marv Heston
...Show more →
I just read through your posted link, and you sir, deserve a medal for your sleuthing and dedication to documenting this issue. Hopefully, someone at CPS is paying attention and feeding this back into the product development team.
Hopefully this can actually be addressed with product updates and does not require Canon to abandon the existing RT radio design.
