garyvot Offline Upload & Sell: On
shredder1656 wrote:
Thanks, again, for the input.
Another question: Can an EF adapted to R lens add a 1.4 or 2x converter. Or, is that a waste?
IF an adapter can be added, do you use an R converter on the camera side of the adapter or an EF converter on the lens side? Probably a dumb question, but I honestly have never done this before.
Thanks!
Yes, you can use teleconverters just fine with the adapter. You would want to use an EF teleconverter with an EF lens. The camera registers the combo and adjusts the maximum aperture just as you would expect.
To reiterate what I said earlier, the EF/RF adapter is completely transparent. That is, the adapted EF lens is effectively a native lens on a Canon R body. With the exception of the framerate limitations mentioned above, your lens will have full functionality when using the adapter.
