AmbientMike Offline Upload & Sell: Off
All the slower 1.7-2 50mm I've shot have been good, regardless of age or brand except maybe old Leica Summar but that's a bit different
I'm surprised that you got good results at 2.8, I usually try to get to at least f/4 using them, but then again, my 50/1.8 II looked good at f/2.5 last time I had it out. Even the under $20 mid to late 1960's 50/2 I got used off ebay is really great, nice color and resolution, though I haven't put it on ff yet to check the corners
Modern Photography lens tests used to be pretty popular on here since they tested a lot of alts. They tested the eos 50/1.8, presumably metal mount, and it topped out 63 lp/mm in the center 5.6-8 or so. Adaptall-2.com lists the numbers on some of the older lenses, some like 28-70 44A, 28-80 sp and 35-135 (58mm) did slightly better in the center than the 50/1.8, older lenses can be excellent
