rscheffler Offline Upload & Sell: Off
p.1 #2 · p.1 #2 · What should I replace my Promise Pegasus2 R4 with? | |
You should cross post this to the processing and printing board where there is a lot more computer related discussion.
Are you able to swap out the HDDs in the existing hardware? If so, and assuming the hardware will work with current large HDD capacities, that would seem to be the most straightforward solution if you want to stay with a RAID solution.
Compared to 11 years ago, HDD capacity is much higher now and you could easily buy a simple RAID 1 box and put two 12, 14, 16, 18, 20TB drives in it and be set for another few years (sounds like you don't generate a lot per year).
Another option would be to add a couple high capacity NVME SSDs as your daily go-to storage for access to your files and back those up to a HDD based RAID, or individual cloned HDDs.
For the amount of storage you're using, RAID may not really offer that much now, compared to back when your current box was new. Back then you likely did it for achieving a certain amount of storage capacity greater than the available single HDD capacity of the time (though it took you ~10 years to fill the array) and a certain degree of peace of mind with RAID 5 redundancy (though a RAID isn't really an 'archive' solution).
NVME SSDs offer a lot more speed now compared to a HDD based RAID, up to 8TB capacity, a much, much smaller footprint in respect to size and power consumption, etc., etc.
Whatever the solution you decide on, IMO the most critical aspect will be maintaining a good backup and archiving solution. Seems like you have that covered.
