Problems tethering with Z8 and C1 23
sungphoto
p.1 #1 · p.1 #1 · Problems tethering with Z8 and C1 23
I'm running a macbook pro 16" M1 chip running the latest OS, capture one 23 with needed updates to tether with the Z8/Z9. Tether tools USB-C to USB-C 15 ft, with no booster cable (which I'm guessing is probably the issue).
Most of the time, it takes a few seconds to show the Z8 as connected in Capture One. I often end up having to disconnect everything, restarting and then reconnecting to get it to work for a session. My D850 on the other hand connects right away, and without any issues for the most part.
Anyone else running into this issue with the Z8? Will just getting a booster cable fix this, or should I switch from Tethertools to another brand?
Feb 12, 2024 at 05:49 PM
snapsy
p.1 #2 · p.1 #2 · Problems tethering with Z8 and C1 23
Not sure about the C1 issue but Nikon just released big update to their free NX Tether which added LV support. It works rather well. I did a quick walkthrough video the other day:
You can download the V2 NX Tether here:
https://downloadcenter.nikonimglib.com/en/download/sw/250.html
Feb 12, 2024 at 05:53 PM
macwest
p.1 #3 · p.1 #3 · Problems tethering with Z8 and C1 23
https://www.area51tetherco
copy and paste in browser
Feb 12, 2024 at 06:00 PM
jlafferty
p.1 #4 · p.1 #4 · Problems tethering with Z8 and C1 23
The typical answers to this problem are: 1) remove any cards in camera, 2) install the latest firmware for the camera, 3) get a better cable - not from Tethertools - go with Jebi, LVNA or Area51
Side note: there's no such thing as booster cables at this point that I see in use anywhere regularly - they are a relic of prior gen tether cables, USB3 for sure, and then early USB-C would benefit by a power injection for initial connection (with some camera models). The latest (good) tether cables USB-C to USB-C, solve these issues.
Feb 12, 2024 at 10:26 PM
sungphoto
p.1 #5 · p.1 #5 · Problems tethering with Z8 and C1 23
Thanks everyone. Appreciate the alternatives. Ended up ordering the Jebi 10 meter plus 10 meter extension. Also thanks for the insight on the powered extension boosters - I used them off and on a few years ago, and they were always unreliable so ended up ditching them.
When the setup worked, it was really nice being able to just throw a power bank onto the Z8 and not worry about swapping batteries while it was in a ceiling rig over wet paint
Also got to try out my multiple camera sync (just my D850 triggering the Z8) to one D2 1000 strobe with the JJC cheapo triggers. It worked surprisingly well, so long as both cameras had a trigger on the hot shoe, and I didn't go crazy with my flash pops in terms of FPS. I am going to give the PW multisyncs another try, and just relegate the JJC ones to backup.
Feb 13, 2024 at 10:57 AM
jlafferty
p.1 #6 · p.1 #6 · Problems tethering with Z8 and C1 23
Wow, this looks awesome - thanks for sharing!
Feb 13, 2024 at 11:10 AM
sungphoto
p.1 #7 · p.1 #7 · Problems tethering with Z8 and C1 23
Following up to confirm that the Jebi cables work great with the Z8, Z6ii and D850 (using the extender plugged into the TT cable). All sync up in Capture One in 2-3 seconds after plugging them into the camera. I also like how thin the cable is. Now I just need to recycle the old TT cables. Thanks @jlafferty!
Feb 20, 2024 at 05:52 PM
jmmaher
p.1 #8 · p.1 #8 · Problems tethering with Z8 and C1 23
sungphoto wrote:
Following up to confirm that the Jebi cables work great with the Z8, Z6ii and D850 (using the extender plugged into the TT cable). All sync up in Capture One in 2-3 seconds after plugging them into the camera. I also like how thin the cable is. Now I just need to recycle the old TT cables. Thanks @jlafferty@!
Where might I be able to buy these cables. Can not seem to locate them
Feb 20, 2024 at 07:05 PM
jlafferty
p.1 #9 · p.1 #9 · Problems tethering with Z8 and C1 23
Jebi: https://jebi-studio.square.site/
LVNA: https://lvnadigital.squarespace.com/
Both offer highest spec (10g) and great customer service.
Feb 20, 2024 at 07:58 PM
jlafferty
p.1 #10 · p.1 #10 · Problems tethering with Z8 and C1 23
Be sure to read the tips on the LVNA site:
Always power off the camera in between battery swaps and lens changes.
Never place camera down on surface on tethering side to save your port and cable from bending!
Use a high quality tether lock to secure cable and tethered connection on camera.
Longevity:
Cables shouldn’t be considered expendables. Follow these simple tips to keep your cables in great shape and ready for every shoot!
Keeps your cables in 10-12” coils and use a velcro tie to secure ends.
Always follow the memory of the cable when coiling and gently work out any kinks.
For heavy kinks - lay your cable out in the sun for 5-10 minutes and gently work them out, then recoil. This will work wonders for cables that won’t coil nicely!
Do not submerge cable into water.
Do not roll over your tether cables with monitor stands, carts, dolly, rollerblades, skateboards, crafty tables, makeup tables, etc. Same applies to dropping things on the cable. It will break. :/
Feb 20, 2024 at 08:01 PM
jmmaher
p.1 #11 · p.1 #11 · Problems tethering with Z8 and C1 23
Thanks to all - ordered the 10M from Jebi. Hoping for great success with my Sony A7RV
Feb 21, 2024 at 02:56 PM
macwest
p.1 #12 · p.1 #12 · Problems tethering with Z8 and C1 23
https://support.captureone.com/hc/en-us/articles/16882710785053-Capture-One-Pro-16-3-6-Release-Notes#h_01HQ2Q70MS54FEHJAYJRW144DE
see if any better with update.
Feb 22, 2024 at 06:05 PM
sungphoto
p.1 #13 · p.1 #13 · Problems tethering with Z8 and C1 23
Thanks. No issues since I picked up the Jebi cables to replace my old TT ones, which have seen several years of use so probably worth replacing anyways.
Feb 26, 2024 at 01:35 AM
macwest
p.1 #14 · p.1 #14 · Problems tethering with Z8 and C1 23
ok all is well, good. Mac
Feb 26, 2024 at 11:16 AM
story_teller
p.1 #15 · p.1 #15 · Problems tethering with Z8 and C1 23
Can anyone supply a link for the Jebi tether cables. Appreciate it!
Feb 27, 2024 at 08:11 AM
jmmaher
p.1 #16 · p.1 #16 · Problems tethering with Z8 and C1 23
Mine arrives today
Feb 27, 2024 at 08:38 AM
story_teller
p.1 #17 · p.1 #17 · Problems tethering with Z8 and C1 23
Mine arrives today
Thanks!
Feb 27, 2024 at 03:20 PM
jmmaher
p.1 #18 · p.1 #18 · Problems tethering with Z8 and C1 23
Mine arrived and I tested it (jebi 32 foot) just now. Seems to work great in my test. Nice light cable.
Feb 27, 2024 at 03:26 PM
