       2       3              13       14       end
Nikon Z8 firmware 2.0
lukemeup
p.1 #1 · p.1 #1 · Nikon Z8 firmware 2.0
https://downloadcenter.nikonimglib.com/en/download/fw/514.html
BOOM.
■ Still Photography
• Added [Pixel shift shooting] to the photo shooting menu.
• Added new picture controls.
• Added [Birds] to [AF subject detection options] in the photo shooting menu.
• The maximum shooting display zoom ratio is now 400%.
• Added [Auto capture] to the photo shooting menu. Users can select capture criteria from [Motion] (the direction the subject is moving), [Distance] (how far the subject is from the camera), and [Subject detection] (whether or not a subject of a given type is detected), and the camera will take photographs automatically while it detects subjects that meet the selected criteria. Note that [Distance] is available with NIKKOR Z lenses and may not function as expected when used with other lenses. The [FX (36Χ24)] and [DX (24Χ16)] image areas are available with auto capture.
• The length of time the camera will continue to buffer frames before cancelling shooting during the Pre-Release Capture phase of high-speed frame capture + has been increased from 30 to 300 seconds.
• Added [Large] to the size options available for [Secondary slot function] > [JPEG primary - JPEG secondary] in the photo shooting menu.
• Added new bracketing increments for use during auto bracketing with [AE & flash bracketing], [AE bracketing], or [Flash bracketing] selected for [Auto bracketing set]. This change also applies to [Interval timer shooting] > [Options] > [AE bracketing] > [Increment].
■ Video Recording
• Added [Birds] to [AF subject detection options] in the video recording menu.
• Added [Auto capture] to the video recording menu. Users can select capture criteria from [Motion] (the direction the subject is moving), [Distance] (how far the subject is from the camera), and [Subject detection] (whether or not a subject of a given type is detected), and the camera will record video automatically while it detects subjects that meet the selected criteria. Note that [Distance] is available with NIKKOR Z lenses and may not function as expected when used with other lenses. The [FX] and [DX] image areas are available with auto capture.
• Added low ISO sensitivity options to [ISO sensitivity settings] > [ISO sensitivity (mode M)] for use during N-Log video recording.
• Changed the range of speeds available for Hi-Res Zoom.
• Added slow-motion video recording.
■ Playback
• Added [Playback speed] in the video playback “i” menu.
• Added [Auto image rotation] in the playback menu.
• Added [Auto series playback options] to [Series playback] in the playback menu.
• Made changes to the [Select for upload to computer] and [Select for upload (FTP)] items in the playback “i” menu and added [Select for priority upload to computer] and [Select for priority upload (FTP)].
■ Controls
• Added [Half-press to cancel zoom (MF)] item to the [CUSTOM SETTINGS MENU] in positions d18 and g17.
• Added [Focus point border width] to a11 [Focus point display] in the [CUSTOM SETTINGS MENU].
• Changes have been made to how a full format is performed with [Format memory card] in the [SETUP MENU].
• White balance and exposure compensation can now be adjusted while recalling the shooting function settings.
• Added support for the power zoom feature on power zoom lenses.
• Added an [Exposure delay mode] item to the [CUSTOM SETTINGS MENU] in position d6.
• Added to the custom controls and roles assignable via the following items in the [CUSTOM SETTINGS MENU]. New reset options have also been added.
- f2[Custom controls (shooting)]
- f3[Custom controls (playback)]
- g2[Custom controls]
Choose [Prefer focus point] or [Prefer focus point (face priority)] for f3 [Custom controls (playback)] > [Main command dial] or [Sub-command dial] > [Frame advance zoom position].
The settings for f3 [Custom controls (playback)] > [Main command dial] or [Sub-command dial] > [Frame advance] can now be applied during playback zoom.
• Made updates to [Non-CPU lens data] in the [SETUP MENU].
• Increased the character limit from 3 to 256 for “Category” entries in IPTC presets.
• Restructured the [Camera sounds] item in the [SETUP MENU] with the addition of new options, including new sounds and volume level adjustment for the electronic shutter.
■ Displays
• Added focus-distance information to the focus distance indicator displayed during manual focus.
• The option selected for [Viewfinder display size] (formerly [Finder display size (photo Lv)]) in the [SETUP MENU] now also applies in video and playback modes.
■ Network (Also NX Field)
• A warning now appears when the connection to an ATOMOS AirGlu BT accessory is unstable or disrupted.
• ATOMOS AirGlu BT accessories and MC-N10 remote grips can now be used together.
• Made changes and additions to the [Connect to FTP server] item in the [NETWORK MENU].
• Changed the procedure used when configuring the camera for synchronized release, increasing to twenty the number of groups that can be created, while the number of cameras in each group that can be controlled from the master camera has been increased to sixteen.
• Added [Overwrite copyright info] under [Connect to other cameras] in the [NETWORK MENU].
■ App-Related Changes
With NX MobileAir:
• the camera live view display for photo mode now shows NX MobileAir status, and
• camera settings saved to a memory card using [Save/load menu settings] can now be downloaded to the smart device or copied from the smart device to the camera memory card using NX MobileAir.
■ Other Changes
• The time the shooting display goes dark after shutter is released when [ON] is selected for [Photo flicker reduction] in the [PHOTO SHOOTING MENU] has become shorter.
• Improved the accuracy of [3D-tracking] for small, fast-moving subjects when [Auto], [People], [Animal], or [Vehicle] is chosen for [AF subject detection options] and no subject of the selected type is detected.
• Improved focus lock-on with flicker detection in low-speed continuous release mode.
• Made other improvements to the autofocus operation and its reliability.
• Fixed an issue that sometimes resulted in the viewfinder darkening during playback when [Auto] was selected for [Viewfinder brightness].
• It is now easier to obtain the correct exposure from the first shot during interval-timer photography in high-contrast settings or settings dark enough for starlight view.
• The histogram display is no longer available when starlight view is enabled.
• Changed the video low-capacity warning so that it is now displayed in white on a red background when there is less than one minute remaining. The warning is now also displayed when recording is not in progress.
• Users now have more precise control when scrolling through videos during playback using the progress bar.
• When [AF-area mode] is set to [3D-tracking] and the human subject is large relative to the frame and multiple eyes are detected near the tracking focus point, the camera will assign priority for focusing to the eye closer to the point.
• The RGB histogram is now easier to view when [Mode 1] or [Mode 2] is selected for d11 [Warm display colors] in [CUSTOM SETTINGS MENU].
• Fixed the following issues:
- Photos taken with interval-timer photography could sometimes be underexposed.
- Flash may not sometimes fire during focus shift.
- The focus position unintentionally returned to the position saved using [Save focus position] if standby timer was expired while power was supplied via USB and a WR-R10 was attached.
- Optimal exposure could sometimes not achieved in burst or focus shift shooting.
- Pressing the AF-ON button immediately ended playback when [Playback] was assigned to [AF-ON button] and [Prioritize viewfinder (2)] was selected for monitor mode.
- Shutter release was sometimes disabled when “Bulb” was selected for shutter speed.
- Focus point selection using the multi selector and sub-selector was unavailable if a touch operation was performed using [Position focus point] when [3D-tracking] was selected for AF-area mode.
- Fine-tuning values set in [AF fine-tuning options] in the setup menu did not apply while the subject is detected with [Wide-area AF (S)], [Wide-area AF (L)], [Wide-area AF (C1)], or [Wide-area AF (C2)] selected for [AF-area mode].
Feb 06, 2024 at 08:32 PM
RoamingScott
p.1 #2 · p.1 #2 · Nikon Z8 firmware 2.0
I’d be raging if I shot a certain brand that never gets FW updates. Nikon is KILLING it.
Adding focus distance display is a great get for the MF crowd!
Feb 06, 2024 at 08:35 PM
cvrle59
p.1 #3 · p.1 #3 · Nikon Z8 firmware 2.0
Just on time, before spring migration starts, I love it!
Feb 06, 2024 at 08:40 PM
BPsmith511
p.1 #4 · p.1 #4 · Nikon Z8 firmware 2.0
Improved Bird AF, PIXEL SHIFT, autocapture this is definitely a huge update. Way to go Nikon, the Z8 is turning out to be a solid workhorse.
Wonder if one of the new picture controls is deep tone monochrome from the Zf.
Also got exposure delay mode so people can FINALLY stop crying about it for some reason.
1bwana1
p.1 #5 · p.1 #5 · Nikon Z8 firmware 2.0
Looks like a powerful upgrade. Well done Nikon!
Feb 06, 2024 at 08:44 PM
suteetat
p.1 #6 · p.1 #6 · Nikon Z8 firmware 2.0
Excellent, just in time for my trip next week
Feb 06, 2024 at 08:46 PM
lukemeup
p.1 #7 · p.1 #7 · Nikon Z8 firmware 2.0
Finally the repetitive speculations that the Z8 is not getting some of the Z9 goodies can be put to rest. Firmware installed fine for me - testing when I have time this weekend.
groob
p.1 #8 · p.1 #8 · Nikon Z8 firmware 2.0
Amazing!
So, is pixel shift the only functional difference between the Z8 and Z9 now?
Feb 06, 2024 at 08:52 PM
40Driggs
p.1 #9 · p.1 #9 · Nikon Z8 firmware 2.0
Well played Nikon. Z8 is an even better value now, and it was already packing a lot of punch.
Feb 06, 2024 at 08:53 PM
RoamingScott
p.1 #10 · p.1 #10 · Nikon Z8 firmware 2.0
There are a whole bunch of things in this update that the Z9 doesn’t have yet. 😠
groob wrote:
Amazing!
Feb 06, 2024 at 08:58 PM
lukemeup
p.1 #11 · p.1 #11 · Nikon Z8 firmware 2.0
That suggests Z9 will get those changes soon enough. Plus some extras so Z8 owners can speculate how they're never coming.
Feb 06, 2024 at 09:00 PM
cmm1398
p.1 #12 · p.1 #12 · Nikon Z8 firmware 2.0
My Z8 is updating as I type.
Feb 06, 2024 at 09:03 PM
RoamingScott
p.1 #13 · p.1 #13 · Nikon Z8 firmware 2.0
It’s undoubtedly THE midrange camera of 2024 and it’s only on its second major FW. Nothing else comes close to the full package it represents at its price.
Feb 06, 2024 at 09:11 PM
groob
p.1 #14 · p.1 #14 · Nikon Z8 firmware 2.0
Are there? Guess I haven't used my Z9 enough to get into all the nuances. Pixel shift was the only thing that jumped out.
Feb 06, 2024 at 09:16 PM
lukemeup
p.1 #15 · p.1 #15 · Nikon Z8 firmware 2.0
One of the new custom controls is 'cycle af-area mode'. You can switch between focus modes of your choice with a simple press of a button. I'll have to rethink my setup now .
Some new shutter sounds have also been added (no cat's meow though ).
Feb 06, 2024 at 09:32 PM
Joseph Marney
p.1 #16 · p.1 #16 · Nikon Z8 firmware 2.0
Well done!
Feb 06, 2024 at 09:41 PM
Jman13
p.1 #17 · p.1 #17 · Nikon Z8 firmware 2.0
My god. Is this the biggest firmware update ever given to a digital camera? This is an ungodly amount of upgraded and new features. Holy hell. Guess I’ll need to download my Z8 Mark II tonight.
Feb 06, 2024 at 09:43 PM
RoamingScott
p.1 #18 · p.1 #18 · Nikon Z8 firmware 2.0
Z9 4.0 added more new features, but this is a close second.
Feb 06, 2024 at 10:12 PM
suteetat
p.1 #19 · p.1 #19 · Nikon Z8 firmware 2.0
On dpreview, they mentioned ability get out of zoom mode in manual focus by half pressing shutter release button. I have been waiting for this forever.
New shutter sound, no mentioning of meow sound though
Also no mentioning of eye detection in manual focus mode like Zf.
Definitely sounds like much more upgrade than just playing catch up with Z9.
Todd Warnke
p.1 #20 · p.1 #20 · Nikon Z8 firmware 2.0
Yep, Flat Mono and Deep Tone Mono are there.
Feb 06, 2024 at 10:32 PM
       2       3              13       14       end
       2       3              13       14       end
