RustyBug Online Upload & Sell: On
The wider you go, the tougher it gets.
Thngs like vignetting, distortion, CA, etc. become more challenging to control as the angles of incidence change.
I'm not versed in Sony, but ... there are two main things that come to mind, and a few others that follow.
#1 the Sony mount is in fact larger, and this changes the angles of incidence that the designers have to work with. I understand your question isn't Sony vs. Leica, rather Sony vs. Sony and Leica vs. Leica, at why not a parallel size relationship in each brand.
#2 the level of correction(s) and the methods of design used to achieve them vary. I think it would be interesting to see the lens diagram for ALL FOUR lenses to assess if Sony retained the SAME approach in both their 35 and 24. Also, if Leica retained the SAME approach for their 35 and 24.
It was mentioned that Sony "got better" and the 35 was an early design. IF (I'm not versed in Sony) that is true that Sony used DIFFERENT designs between the 35 and 24, while Leica used similar designs to retain consistency between the drawing style of their 35 and 24, then that could vary well be your differential for the non-sequitur aspect that Leica got larger (following the "wider you go, the tougher it gets" paradigm, for ceteris paribus), while Sony managed to get smaller.
The 'assumption' being that BOTH Sony and Leica remained consistent within their lens design pairing. Until we see the lens diagrams for the four lenses, we cannot make that assumption for BOTH Sony and Leica as to whether the retained the consistency between their 35 and 24 counterparts ... or, if they deployed a different approach between the pairings.
NOW, as to whether or not Leica CAN make a smaller 24/1.4 that is smaller than their 35 counterpart ... certainly they can. But, the question becomes at what expense in the quid pro quo to do so.
Different drawing style, breaking consistency from the 35 Lux
More vignetting
More distortion
More CA
One point about distortion ... designing with simple distortion vs. designing with complex (mustache) distortion affords different approach opportunities, too.
Without seeing the lens diagrams of all four ... we will continue to be guessing. But, a quick guess on my part is that Sony did NOT use the same design approach for their 24 as their 35. Then, the following question is what also changed in drawing style, vignetting, distortion, CA, etc. as a result of that. Because, in order to retain ceteris paribus of a 35 and 24, the 24 would need to be larger, or would incur more aberrations. So, that brings the point of how much OPTICAL correction did Sony forego in the 24, and did they design the 24 with the allowance for COMPUTATION correction, instead of OPTICAL correction. Meanwhile did Leica retain similar drawing style and OPTICAL correction levels. I don't have the answers, but these would be (some) of my questions in quest of your search for the rationale as to the difference of why Sony did it, but Leica did not.
Again, I'm not versed in Sony, but these are aspects that I'd seek to know. The question regarding the non-sequitur relationship is based on the assumption of ceteris paribus between the 35 and 24 pairings. But, I'd venture that the ceteris paribus of Leica is more closely aligned than that of the Sony pairings. Again, we need to see the lens diagrams of all four to understand how much ceteris paribus is actually retained, vs. departed from.
Then, we'd need to see the comparative results of the optical projections of all four lenses, to see where the quid pro quo may have occurred that allowed for the smaller physical size of the Sony 24 from its 35 brethren.
Without the lens diagrams and the MTF's, distortion, vignetting, CA performance information ... to verify or refute the assumptive nature of non-sequitur vs. ceteris paribus, we are left to a speculative conjecture.
Hopefully someone will post up the optical information (of all four) needed to draw better determinations, or better illustrate the difference(s) that will unfold to answer your question.
Short answer ... something is different between the Sony 35 / 24 more so than Leica retaining more of the same between their 35 / 24 is my guess.
One other thing that comes to mind ... since the f/1.4 is based on central measurement, T-stops would be interesting to note for the four lenses (pairings) as well.
