CanadaMark Offline Upload & Sell: Off
It probably depends on what Canon decides the target market is for the camera, assuming we're talking about the long rumored R1. The A9III seems to be a niche camera aimed squarely at sports photographers. Take away the global shutter, and it's basically an A9II with modernized AF and a faster frame rate (not at all a bad thing). The price premium you pay for the global shutter appears to be very steep, though that isn't unreasonable with no viable alternatives.
Sensors with global shutters typically have a narrower ISO range, worse DR, higher power consumption, and higher base ISO. At least on paper, it seems those remain tradeoffs for the A9III. Dumping the data from 24MP all at once is impressive as it is, but if the R1 is going to have 45+ MP, it would be that much harder to do. Canon is a huge company with lots of resources though, so you never know.
The main advantages of a global shutter are of course no rolling shutter, extremely fast shutter speeds, fewer issues with LED/difficult lighting, and extremely fast sync speeds. For the most part, those things are already achieved with existing stacked sensor bodies outside of niche cases. 1/80,000 flash sync sounds cool on paper, but the flashes that can actually do that cost more than a car and can only do so at an extremely low power level.
What the A9III will be very good at will be things like dealing with LED lighting at sports events, extreme niche applications like capturing a bullet leaving a gun, and guaranteeing certain 'target' spots frames such as a baseball leaving a bat with zero distortion and a RAW file to work with (120fps+ is already available in existing bodies but not in RAW).
My personal guess would be that the R1 does not use a global shutter unless they can overcome all the downsides that currently exist, unless they are going to also position the R1 as a specialized sports body, but they already have a fast, low-ish MP body with the R3.
The thing I really appreciate is that there is now a global shutter in a mainstream FF camera. Going forwards, all the major camera companies will be pouring resources into overcoming the existing drawbacks and everyone is likely to benefit at some point.
