R6 Mark II sticky shutter release in continuous shooting mode?
rscheffler
p.1 #1 · p.1 #1 · R6 Mark II sticky shutter release in continuous shooting mode?
Hi all,
Wondering if anyone else has experienced a similar situation with their R6 Mark II (or any other R body):
Camera set to H (not H+) advance rate in EFCS to get ~7fps. Sometimes I want to shoot brief sequence of 2-3 frames with some subject content variation between the frames (sports subjects) and sometimes I want to just fire a single frame. I find this fps rate to be a good sweet spot.
On rare occasions, when I press the shutter release to do a single frame with the above configuration, the camera will fire an additional 3-6 frames. It's obvious when this happens because I'm no longer actually pressing the shutter release, yet the camera is still capturing images. I'd guess it maybe happens once every few hundred frames, but is not consistently spaced. Sometimes it happens a few times per game/event. Sometimes I can go multiple games/events before it happens. Each game/event is typically around 150 images.
Sometimes it appears to happen when I 'stab' the shutter release - push it harder than normal when a sudden moment of action occurs that I want to capture as a single frame. But this is not always the case.
The specific sports application where this occurs is mostly vertical images. I initially thought maybe there was a problem with the BG-R10 grip's shutter release button, but it recently also happened when capturing a horizontal image using the camera's shutter release button. For it to be a problem with both buttons IMO is rather unlikely. One thought was that the shutter release buttons are able to register the amount of pressure applied and when a sufficient threshold is reached, will determine that a sequence rather than a single frame is warranted. But I don't recall seeing any documentation related to such a feature and kind of doubt it's the answer.
I haven't noticed this behavior on H+ where I'm typically intentionally shooting longer sequences and not trying to squeeze off single frames (and usually in full e-shutter). But maybe it happens there too. Unfortunately I can't test this in 'live' situations because it will create too many images for the end use (there is no time to do additional culling).
I'm guessing the likelihood of someone else experiencing this will be remote, but thought I'd ask anyway.
Nov 06, 2023 at 10:49 AM
AmbientMike
p.1 #2 · p.1 #2 · R6 Mark II sticky shutter release in continuous shooting mode?
No shortage of shutter release button issues over the years, mine stuck in the on position this summer, had to stop and dry it out due to sweat getting in there. Hot summer.
Any moisture involved?
Nov 06, 2023 at 11:46 AM
Gochugogi
p.1 #3 · p.1 #3 · R6 Mark II sticky shutter release in continuous shooting mode?
You mastered the quick poke far better than me. In H drive I get off two frames half the time rather than one. Not had the shutter stick in my R6 MK II even once during the past year. Stopped freezing after one of the early FW updates too.
Nov 06, 2023 at 12:34 PM
rscheffler
p.1 #4 · p.1 #4 · R6 Mark II sticky shutter release in continuous shooting mode?
That reminded me I hadn't yet applied firmware version 1.2 because it didn't seem to address anything relevant to my uses. I've installed it, so we'll see.
Mike: I don't think it's a sticky shutter button because it happened when using the shutter release on both the grip and the camera. The situations in which it happens are all inside, dry and low temperature where sweat is not a problem.
Nov 06, 2023 at 02:40 PM
Imagemaster
p.1 #5 · p.1 #5 · R6 Mark II sticky shutter release in continuous shooting mode?
Not sure why anyone would call it a shutter release button issue when the camera is programmed to take 7fps and the operator tries to take 1 single frame. When one is talking about holding the shutter button down for only a fraction of a second to get just one shot in that scenario is a rather iffy procedure that I would not fault the camera for.
Nov 06, 2023 at 02:49 PM
jojib
p.1 #6 · p.1 #6 · R6 Mark II sticky shutter release in continuous shooting mode?
I haven't tried shooting a single shot when I am on FPS. I also use the vertical grip for my R6MKII. For model coming straight at me shots I dedicate C3 with high FPS using electronic shutter. So I just click away :-) Slightly OT----I should be making reels for this.
Nov 06, 2023 at 03:33 PM
rscheffler
p.1 #7 · p.1 #7 · R6 Mark II sticky shutter release in continuous shooting mode?
If it can't consistently do just one frame when momentarily pushing the shutter release (which it actually can, because I do it frequently), it will only do two. But I'm getting up to around 7 frames, well after I have lifted off the shutter release. The camera is effectively shooting on its own at this point. I have never had this happen with any other camera over several decades of photography. During all those years I have almost always used continuous advance mode, even if I usually only squeezed off one frame.
Nov 06, 2023 at 09:06 PM
