SCoombs Online Upload & Sell: Off
I just received the 40mm/2 today so went to test it on my Z8. I was not expecting perfection and indeed on initial testing I found it to be a bit soft wide open but to sharpen up reasonably well around 2.8 and especially 3.5. Later in the evening I went to do some more tests - this time with the flash since it had gotten too dark - and suddenly I was having a huge trouble getting sharp photos. I noticed it especially when trying to photograph people in glasses, which can sometimes be a problem but which the Z8 hasn't really had a big problem with for me.
At first I attributed this to the softness wide open so stopped down again, but this didn't improve things. In fact, I seemed to find f/4 to be extremely poor - not simply soft, but essentially out of focus. I did a lot of experimentation with aperture, shutter speed, IBIS, etc. and found a lot of inconsistency. 9/10 shots was quite poor. Putting my 70-180 on - which has been extremely sharp for me - I did see improvement, but was a bit surprised to get a much larger ratio of poor shots than I have seen from this lens before.
Eventually I started to suspect something was off with the camera's ability to focus in the lighting and started playing around with ways to improve matters. It was getting a better success rate in brighter rooms than dimmer. I tried playing with the setting which adjusts the viewfinder/viewscreen for ease of viewing when using a flash because the camera uses the EVF feed for AF, but I didn't have much success with that.
Then I found something very unusual. If I take the flash off of manual and put it in TTL and take ISO off of manual and set that to auto, the camera started nailing almost every shot. The viewfinder was not any brighter, for what it's worth, Also, it didn't matter what ISO I "suggested" to the camera - i.e., if you set the ISO to auto but then, while keeping it in auto, select an ISO value it seems to treat that value as a kind of soft cap and only increases beyond that if necessary. With the flash, if I set the ISO to auto-3200, my photos are ISO 3200 but the EVF and final photo have about the same brightness as if I set it to auto-400, but the photo will be ISO 400. My point here is that either way, the camera's focus was working much, much better with these settings. Even the eye-detect box was noticeably more secure and seemed to adjust at a much faster rate as the subject moved around - and it stayed mostly green, whereas with all the same settings except for the flash and ISO being on manual I'd get a lot of yellow for the eye box.
Of note is that this all applies even when my images were well exposed in 100% manual. I am fairly certain I was setting the exposure correctly with the flash/ISO in manual - the AF was just working far less reliably.
Any idea what is going on here? In particular, I'd really prefer to be able to use manual flash, but it seems I'm getting almost unusable AF performance on the 40mm and extremely inconsistent performance on at least one other lens when doing so.
