jedibrain Offline Upload & Sell: Off
p.1 #4 · p.1 #4 · Help with Settings - Canon R3 for night football game | |
Agree with the above that something was messing with your metering. I have a couple of thoughts I'd try. I shoot sports as well, but usually not on lighted fields.
1. Set your meter mode to the smallest possible area.
2. Shoot M mode, and set your Tv to capture action around 1/1600-1/2000, and your aperture wide open. Then set ISO to get the right exposure as described above, using an image that doesn't have the sign in the background.
3. I normally shoot Manual, Auto ISO. That could work for you as well, if you get the meter weighting small enough to ignore the sign in the background. OR - it is also possible to use manual, auto ISO with exposure compensation. You could set it to +1EV of EC, to account for the fact that the sign is going to mess with the foreground exposure. I will say its kind of hard to tell the EC is set and working, at least on my R6.
Flicker warning is because it detects LEDs, which can have a refresh rate that shows up in images. R3 has a flicker mode where it can detect the period of the LED, and set a Tv to account for it. LIke 1/123.3 or other unusual numbers like that. You can read the manual to see if that is something you want to try and turn on. It may limit the max shutter speed you can attain, I'm not sure.
With the right exposure, and good denoise software, I have gotten pretty clean and detailed images at up to ISO52600. So you should be able to do the same with your R3.
-Brian
