Firmware update - A7r5 - 2.0.1
MikeEvangelist
p.1 #1 · p.1 #1 · Firmware update - A7r5 - 2.0.1
Newly released. Nothing exciting; just housekeeping.
Here's the changes:
• Fixes an issue where JPEG files could not be enlarged and played
• Fixes an issue where the power may not turn on or turn off even if the Power switch is used
• Fixes an issue where the Switch V/H AF Area feature may not work correctly
• Fixes a Creators' App issue where the Auto Time Correction and Auto Area Adjustment features may turn off
• Improves the operational stability of the camera
https://www.sony.com/electronics/support/e-mount-body-ilce-7-series/ilce-7rm5/software/00292267
Oct 19, 2023 at 06:46 AM
PaulCStudios
p.1 #2 · p.1 #2 · Firmware update - A7r5 - 2.0.1
Thanks Mike,
Did not get a notice on that one. Will not be the first to update since I am in the middle of a job.
Oct 19, 2023 at 06:51 AM
saaketham
p.1 #3 · p.1 #3 · Firmware update - A7r5 - 2.0.1
This is the main thing ...
After installing this, I no longer need a tripod
Oct 19, 2023 at 07:00 AM
chad hites
p.1 #4 · p.1 #4 · Firmware update - A7r5 - 2.0.1
Thank you for posting this Mike!
Oct 19, 2023 at 07:28 AM
Karl Witt
p.1 #5 · p.1 #5 · Firmware update - A7r5 - 2.0.1
Karl
Oct 19, 2023 at 07:32 AM
sismailian
p.1 #6 · p.1 #6 · Firmware update - A7r5 - 2.0.1
Well i guess some update is better than none. Stability updates are welcome 😁 I'll probably update bit later.
Oct 19, 2023 at 09:22 AM
InFocus2014
p.1 #7 · p.1 #7 · Firmware update - A7r5 - 2.0.1
Wow... a completely painless update using a memory card! That, combined with all the other recent model-feature upgrades, leaves me really searching for things to gripe about.
Oct 19, 2023 at 02:55 PM
AGeoJO
p.1 #8 · p.1 #8 · Firmware update - A7r5 - 2.0.1
😜 and yes, using a memory card and apparently, that’s the only way to upgrade the FW of the A7r V now.
Oct 19, 2023 at 04:51 PM
winkopp
p.1 #9 · p.1 #9 · Firmware update - A7r5 - 2.0.1
I used the Creator's App to upload my A7RV, worked fine and didn't take long.
Oct 20, 2023 at 11:28 AM
Dj R
p.1 #10 · p.1 #10 · Firmware update - A7r5 - 2.0.1
wedding tomorrow.
going to wait until I read two pages of your findings (y'all), until I install.
Thank you Michael
Cheers all
Oct 20, 2023 at 01:10 PM
prosumerhacks
p.1 #11 · p.1 #11 · Firmware update - A7r5 - 2.0.1
Good time to try updating firmware via the Creators app.
Oct 21, 2023 at 04:21 PM
tsdevine
p.1 #12 · p.1 #12 · Firmware update - A7r5 - 2.0.1
Not the fastest, but it worked for me.
Oct 22, 2023 at 09:06 AM
seaSharp
p.1 #13 · p.1 #13 · Firmware update - A7r5 - 2.0.1
I would be very nervous about doing a firmware update via a Sony phone app. Doing the update by loading it onto an SD card and having the camera read that seems much simpler and less error prone.
Oct 22, 2023 at 10:11 AM
tsdevine
p.1 #14 · p.1 #14 · Firmware update - A7r5 - 2.0.1
The app just loads it to the camera. The upgrade is initiated on the camera with no interaction back to the phone.
Oct 22, 2023 at 10:31 AM
kshatch
p.1 #15 · p.1 #15 · Firmware update - A7r5 - 2.0.1
Just updated mine as well - via the Creators app. Very simple and quick. Seems to have worked fine.
Oct 22, 2023 at 05:13 PM
Viramati
p.1 #16 · p.1 #16 · Firmware update - A7r5 - 2.0.1
Just got my A7r5 today and finally a quick and easy way to update firmware. The whole process from downloading the update to finishing installation with the SD card took around 10 minutes.
Oct 23, 2023 at 11:26 AM
Dj R
p.1 #17 · p.1 #17 · Firmware update - A7r5 - 2.0.1
quite surprised we don't have more chatter here
no issues?
Oct 23, 2023 at 02:19 PM
tsdevine
p.1 #18 · p.1 #18 · Firmware update - A7r5 - 2.0.1
I shot quite a bit yesterday, only AF lens was the Batis 135 and I was doing landscape shooting. No issues.
no issues?
Oct 23, 2023 at 02:22 PM
Dj R
p.1 #19 · p.1 #19 · Firmware update - A7r5 - 2.0.1
thx Tim!
Oct 24, 2023 at 07:51 AM
RoamingScott
p.1 #20 · p.1 #20 · Firmware update - A7r5 - 2.0.1
How do you update the firmware if the power switch doesn't work
Oct 24, 2023 at 08:17 AM
