wind30 Offline Upload & Sell: Off
rscheffler wrote:
I'm curious but can't you address this high electronic shutter option with a camera like the a1 to replace your a7r4? Wouldn't it have fewer e-shutter banding concerns under artificial lighting because of the stacked sensor? Or are you primarily interested in the 85/1.2 DS?
I use the R6II with the 28-70/2 and find the IBIS is very effective but have not thoroughly tested it for how low I can hand-hold at 70mm. I don't have any non-IS lenses that cover 85mm and with Canon, if you turn off the lens IS, it also turns off IBIS. I just tried the R6II and 28-70 combo and got consistently good results down to 0.8-1.0 seconds. Not all were perfect, but the vast majority would be usable IMO. At 2.0 seconds there were some signs of slight movement, but downscaled would likely be unnoticeable.
Also note that the R5/6/6II drop to a lower bit depth in e-shutter. I believe it's 12-bits, which could have an impact if you're trying to stay at ISO 100 and wide open in high contrast sunlight conditions. According to Photons to Photos, for the R6II, (link to chart) it's a 2-stop loss at ISO 100 and roughly equalizes in the ISO 800-1600 range....Show more →
A1 is significantly more expensive and it does not have the improved ibis, the lcd screen, the ai af, the focus breathing, focus map, stuff that the a7r5 can give me. I feel a1 and a9 is not a better combo vs a7r5 and a9
Yes, I also want the 85mm f1.2 ds and this is the main mover to switch.
I am just trying to figure out the user experience of the r6ii.
Edited on Oct 09, 2023 at 09:44 PM · View previous versions
