Abbott Schindl Online Upload & Sell: Off
TomSchriefer wrote:
I've been caught with my pants down. I only shoot in M and Av, so I assumed (thought) that it worked in all modes. In Manual, you can have the front dial do aperture, and the rear do shutter speed. In Tv and P, the idea doesn't even make sense. I put aperture on the front dial in M so that it matches Av mode. Apologies for my confusion. I'm leaving my original posts as testimony to my shortcomings.
In a way, it actually does make sense. Think, "I've set my camera to operate in a particular mode, and the front dial is the one I'm most likely to operate first." Then, having the front dial adjust shutter speed in Tv mode, aperture in Av mode, and whatever you want in M mode works.
I only shoot in M mode, and I've programmed the C functions to do what I need. So C1 is M bursts, C2 is Av, and C3 is a different M mode. I've then programmed the dials to do what I most use in each mode and can switch modes to accommodate what I'm shooting trivially easily. I shoot a lot of birds/wildlife using M bursts and nature using Av or M single shot, and find it's much easier to just switch C modes and have everything I want set close to what I need at the time.
