gdanmitchell Offline Upload & Sell: Off
p.1 #3 · p.1 #3 · X-Mount Travel Lens Kit: Pancake, Ultra-wide zoom and ??? | |
oguruma wrote:
I'm looking to build a travel lens set for a Fuji X-T5. I primarily shoot Nikon Z-Mount, but I like Fuji X-Mount more for travel.
I have a few trips coming up: one to Cairo and one to Germany/France.
I'm going to limit myself to 3 lenses and one body. The body will be an X-T5 (unless the X-Pro 4 comes out before then).
I typically go out for some shooting in the early morning while the rest of the family is getting ready for the day, then the rest of the day I'm more focused on spending time with the family than I am on photography, but I still always have a camera at the ready. Unless I am going somewhere notable with the family (castles, museums, etc.) I'll typically just bring a single lens with me during the day, and leave the rest in the room. I'll also typically try to sneak out some time in the evening for a little bit to shoot some more.
I think I want to get:
A pancake for carrying around during the day
An ultra-wide zoom
Either Tele-zoom or tele-photoish prime (90 F2, for instance?).
Given that criteria, and price being no option, which 3 lens would you guys recommend?
...Show more →
I've been using a Fujifilm x-trans based kit of one sort or another for "travel" for over a decade.
("Travel" kit means different things to different people. For me it means a relatively small kit that can make photographs of excellent quality of the subjects I plan to photograph and in the circumstances I'll encounter. For me that usually means traveling light — we almost always limit ourselves to carry-on-only — and primarily but not quite exclusively photographing in more urban environments, with a focus on street photography, some done at night.)
I currently use the XT5. It replaces the XPro2 that I had been using since the time that camera was released.
I rely on the 27mm f/2.8 (v. 2, with the aperture ring) for the great majority of my photography in this situation. This past summer, on a 10-week sojourn to a bunch of places in (mostly) Southern Europe, I think I probably used that lens for 90% of my photographs. Needless to say, I like it a whole lot. The XT5 plus this lens fit into one of the small PacSafe bags that I usually carry. The small size of the package means that I'm not slowed down by heavier gear, and I can photograph without drawing as much attention to myself... which may be an issue with larger equipment.
Augmenting with a zoom can be pretty useful. I own the 16-55mm f/2.8, though I did not bring it on this trip. I've considered carrying only the zoom and the 27mm, using the zoom to replace a few other primes that I do usually bring. (More on that below.) If you are trying to keep weight, size, and cost down a bit, the 18-55mm f/2.8-f/4 "kit" zoom is also a very viable option. It is optically excellent. (My wife carries that lens, and I have used it, too.) If you are looking for a wider Fujifilm than that, I'm afraid that I have no experience with them. I do carry the 14mm f/2.8 prime, and it is wide enough for my travel needs.
As to the longer lens option, there are several interesting choices. None is perfect, so understanding the tradeoffs is important. I do carry the 90mm f/2. (You might be catching on that I like primes — but that won't work for everyone.) It is a fine lens and 90mm is usefully longer than the 27mm lens. A high-end alternative could be the 50-140mm f/2.8. I use it for other things and it is a really good lens — but that is starting to get kind of large and heavy for my approach. Other alternatives include the old 55-200mm and the new 70-300mm zooms. They don't have the f2.8 maximum aperture and they have a variable aperture design... but they are a lot smaller, lighter, and offer wider zoom range and longer maximum length. Construction and IQ wise they are OK... but not in the same category as the 90mm f/2 or the 50-140mm zooms. There are a lot of trade-offs to consider here.
My travel photography is probably different than yours, but here's my basic approach.
1. Most of the time, if I'm going out for a typical day, I carry only the XT5 and the 27mm f/2.8 prime. This lets me travel quite light, it produces good IQ, and it works very well for many urban/street subjects.
2. If I need more flexibility I had the 14mm f/2.8 and/or the 90mm f/2 and use a slightly larger shoulder bag. Do I ever miss having even longer focal lengths? Sure. Do I sometimes wish I had zooms to fill in the gaps? Yes. But do I want to be burdened with the extra bulk and weight? If've learned that for travel I do not. (Having said this, note that have considered using the 16-55...)
3. Because I do a lot of urban night street photography while traveling, I also bring along the 23mm and 35mm f/1.4 lenses. These normally stay in the hotel safe during the day, but when I go out and night I carry one or both of those _instead of_ the other lenses. (Though I've also found that I can phtoogarph well-lit urban areas at night with the 27mm...)
BTW, although I'm not currently using them, the "Fujicron" f/2 lenses —like the 50mm f/2 mentioned above, the 23mm and 35mm f/2 lenses and a few others — are also quite viable options here.
Hope that is useful information.
