EOS R Aberration Correction
dpsaiz
p.1 #1 · p.1 #1 · EOS R Aberration Correction
My wife and both have an EOS R and EOS RP cameras from Canon's refurbished store. Additionally, we have quite bit of EF lenses many of them go back 23 years and further.
We use an EF 28-135mm f/3.5-5.6 IS USM because we've had it for years and with the EF to RF adapter makes it easy to use them. This lens was discontinued 23 years ago.
I attached this lens to my EOS R via the adapter and found that the Digital Lens Optimizer is available for this lens:
  1. Chromatic Aberration Correction
  1. Peripheral Illumination Correction
  1. Diffraction Correction
I was quite surprised that the data correction is available for all three with this older lens.
Is this correct or could my camera be misreading the lens.
Sep 26, 2023 at 03:44 PM
rscheffler
p.1 #2 · p.1 #2 · EOS R Aberration Correction
I don't see why it wouldn't be correct. Have you tried all your old EF lenses and were any of them not supported by in-camera DLO? IIRC the 28-135 was kind of a 'kit' lens for a while, so there were likely many sold and it would warrant DLO support. Also, IIRC, the 28-135 wasn't necessarily a stellar lens, optically, so could likely benefit from DLO.
Sep 26, 2023 at 07:26 PM
exdeejjjaaaa
p.1 #3 · p.1 #3 · EOS R Aberration Correction
it seems it was released in ~1998 and discontinued in ~2010 ...
Sep 26, 2023 at 07:43 PM
Gochugogi
p.1 #4 · p.1 #4 · EOS R Aberration Correction
The only lens I own that lacks a correction profile is the EF 300 4L USM, bought new in 1994. But, yeah, unlike recent designs, it really doesn't need correction.
Sep 26, 2023 at 08:30 PM
AmbientMike
p.1 #5 · p.1 #5 · EOS R Aberration Correction
A lot of canon lenses are supported in DPP. You'd think they could put the corrections in the body.
Sep 26, 2023 at 08:58 PM
MintMar
p.1 #6 · p.1 #6 · EOS R Aberration Correction
I put the old collector items, ahem, lenses onto my R6/2, and looked up DLO.
Available: 20/2.8, 35/2, 50/1.8 metal mount, 24-85 USM
Unavailable: 28-80 USM, 28-70 II, 80-200 II, 100-300L
I guess the oldest EF lens still has it because its optical design was shared with 50/1.8 Mk2.
Sep 28, 2023 at 11:43 AM
sebjmatthews
p.1 #7 · p.1 #7 · EOS R Aberration Correction
Any optics which weren't replaced in the line by 1999* has some degree of correction available; exactly which corrections depend on the age and/or complexity of the optic.
Lenses whose optics were not being used by 1999 do not have any corrections available.
Note that it depends on the optics, not a lens model name; as MintMar correctly guessed, the first EF 50mm f/1.8 has corrections because the optics themselves were still in production after 1999. (In fact that optic didn't get replaced until 2015.)
There are a small handful of exceptions, due to certain older lenses being kept in regular use by a few agencies with enough buying power to force Canon to keep supporting them. But overall, if your optics were obsolete by 1999, corrections won't have been made.
*It's most likely 1999, but the cut-off point might have been very late 1998. It's hard to tell precisely because Canon don't keep track of these things very well and most information is from old, low-resolution scans of Japanese magazines.
Some corrections are stored in the body, others are stored in the lens. Lenses made prior to 2010 don't carry their own corrections, so correction profiles must be loaded into the camera; most bodies made after 2015 come with every 'legacy' profile already loaded in.
If your camera body is missing a profile, you can connect it to a desktop computer and load in profiles via EOS Utility and/or DPP (which one depends on camera model). Most bodies made from 2006-onwards have the capacity to store every correction, though in some cases this can slow down the camera's jpg and video processing very slightly, so it's best to only load in the profiles you'll actually use.
Since 2010, Canon first-party lenses have stored correction profile information within themselves and transmit them to the body during shooting, so nothing needs to be loaded into the body.
Since approximately 2018, Sigma EF-mount lenses also carry their own correction profiles.
Sep 29, 2023 at 04:19 AM
