RustyBug Offline Upload & Sell: On
chez wrote:
Unless you are running a production line, cutting a few prints now and then is no problem with a matte cutter. Op said something like 15 to 20 prints for next years exhibit…that’s peanuts as far as cutting prints.
For some added clarity ... I mention the exhibit more as an example of potential matting. As to prints (without matting), I plan to be cutting down many more small-ish (8x10 > 5X8 or 4x5, etc.) more frequently than cutting mats. I'm sure I'll still be "small potatoes" in certain regard, but I'm thinking to invest in the Rotatrim, and then augment with a basic mat cutter, for the limited number of mats.
Basic thought is that with a 17 inch printer, I'll be cutting down 17x22 sheets to 16x20, so a 24" Rotatrim would suffice. If I went with something of a pano off a roll, I could go longer, but still wouldn't likely be trimming down the long side in that case, anyway.
So, either a 24 or 30 Rotatrim seems to make some sense.
As to the mat cutter, I could just go with the straight bar and a couple of the better cutters Logan offers, and installing it into my own squaring rig (I've got a large guide for my table saw that could do the the trick, or make a replica).
In either regard, I think the small paper trimming needs (handouts / promo / giveaways) will exceed my mat cutting needs in terms of frequency of use (thus, more worthy of the investment) ... and the convenience / ease will be appreciated more often.
I get Chez's point about "double duty", so I'll still ponder this a bit. No hurries, atm ... but, I do see that B&H has a some open box Rotatrims marked down, so I'd be under $300 for a Rotatrim of either 24 or 30 inch. I figure if I go past 24" (as rare as that'll be for me ... if / when), I can straight cut it by hand / ruler. Which, btw ... I do have a fabric cutting table setup for another family member who is very well versed in hand-held long rotary cuts.
Current plan is that larger prints will be outsource (for now). If I eventually grow to getting a larger printer ... then, that would likely be a driver for investing in a larger mat cutter (then, paired with the smaller Rotatrim).
Not sure if that makes sense or not ... still soaking it in, a bit. Still, realizing I'm a newb on this topic.
Thanks for the input(s).
