Canon 11-24 f4 filter system
d4mike
p.1 #1 · p.1 #1 · Canon 11-24 f4 filter system
I've done a search on the forum, but can't find any info on a filter system. The internet is a bit confusing as well.
Sep 16, 2023 at 05:21 PM
khurram1
p.1 #2 · p.1 #2 · Canon 11-24 f4 filter system
Choices depend if you are shooting with R series or DSLR and type of filter system you are looking for.
With my Canon 5dsr DSLR I used ND Grads and ND filters using the Lee SW150 filter system (larger Lee filter sizes and Lee Adapter ring).
Altering going mirrorless, and before I switched entirely to RF lenses, I used the SW 150 II filter holder, Lee Adapter ring for the EF 11-24mm lens with the SW150 ND grad filters. I also used the Canon RF-EF drop-in rear adapter to use drop-in ND filters, Vari-ND filter, and polarizer.
After selling the lens, I sold my EOS EF-RF adapter, drop in filters, and the adapter ring for the 11-24mm lens. You can see a description of the Lee SW150 ND grads and Lee SW 150 II filter holder at the following posting:
https://www.kijiji.ca/v-view-details.html?adId=1669757278&siteLocale=en_CA
You can see a photo of the Lee holder and SW150 ND grad on one of the photos on the listing.
Edited on Sep 16, 2023 at 11:15 PM · View previous versions
Sep 16, 2023 at 11:11 PM
Mike Jacks0n
p.1 #3 · p.1 #3 · Canon 11-24 f4 filter system
What kind of filters are you looking for? NDs, Grad NDs, Circ Pol, etc. Personally, I just use the EF to RF adapter with a drop in filter with mine.
I've seen some that use the conventional filters, but they are massive and cost upwards of $1,000 Lucroit Pro L 165mm.
Sep 16, 2023 at 11:12 PM
tomasr
p.1 #4 · p.1 #4 · Canon 11-24 f4 filter system
With RF you just get drop in adapter. With dslr I wouldn't even bother. You can do most things in post except CPL effect, or very dark ND.
Sep 17, 2023 at 08:12 AM
d4mike
p.1 #5 · p.1 #5 · Canon 11-24 f4 filter system
Thanks guys!
I forgot about the drop in filter adapter! I have the control ring adapter.
A new search is on!
Sep 17, 2023 at 08:41 AM
Flowernut
p.1 #6 · p.1 #6 · Canon 11-24 f4 filter system
I've not done much with it but I'm holding on to my EF superwide lenses as I move to the R system so I can use the drop in rather than the special holders and gigantic square filters. While some of the R replacements may have advantages many have offsetting disadvantages, I've not felt handicapped by doing this.
Sep 17, 2023 at 01:44 PM
jrhoffman75
p.1 #7 · p.1 #7 · Canon 11-24 f4 filter system
https://www.2filter.com/shopsite_sc/store/html/haida-rear-lens-filter-kit-for-canon-11-24mm-f4l-usm-lens.html
Sep 18, 2023 at 02:44 PM
RedWhiteandRed
p.1 #8 · p.1 #8 · Canon 11-24 f4 filter system
The 11-24 with the drop-in polarizer holder on an R5 or other IBIS EOS body is surreal magic - simply terrific to the point of cannot imagine anything better as a wide lens.
Sep 18, 2023 at 03:24 PM
Flowernut
p.1 #9 · p.1 #9 · Canon 11-24 f4 filter system
This filter is different. If using on an ef camera ok. If using on an RF camera, I'd go with the filter holder that is in the ef-rf converter
Sep 18, 2023 at 07:59 PM
robstein
p.1 #10 · p.1 #10 · Canon 11-24 f4 filter system
d4mike wrote:
Thanks guys!
A new search is on!
I like the Meike which I grabbed as a flyer without a lot of research... Same reason - Just improves the EF glass convenience and to me, the filter glass seems like decent quality. It's not as good of a build quality as the control ring Canon I also have. I do wish it had a click for the adjust wheel as hard to tell where you are on range and just feels a bit low quality.
Sep 19, 2023 at 10:01 AM
jj1804
p.1 #11 · p.1 #11 · Canon 11-24 f4 filter system
I agree with the sentiment that ND Grads are pretty much obsolete with todays sensors. Just expose for the highlights and lift the shadows in post. As for drop-in filters I use the polarizer from Canon and a variable ND from Breaktrough. Waited almost a year foe that one but was worth it in the end. There might be other manufacturers in the market today other than breakthrough but I haven’t looked around in a while. They were planning on releasing an IR72 filter that I‘d like to give a try but it wasn’t available last year. If you go drop in I‘d give breaktrough a good look. They are well made and the filter works perfectly for me.
Sep 19, 2023 at 01:35 PM
Flowernut
p.1 #12 · p.1 #12 · Canon 11-24 f4 filter system
Look at Kolari or spencer for additional drop in for canon system.
Sep 19, 2023 at 04:59 PM
Mike Jacks0n
p.1 #13 · p.1 #13 · Canon 11-24 f4 filter system
IMO, Canon's or anyone's EF-RF drop in adapter just made any RF uber wide obsolete on delivery. I just can't see a potential reason to swap over to RF with this option on the EF-RF adapter. I'm sure some people will simply prefer the RF mount, especially if they don't like filters, but for rest of us, these adapters are a big deal.
Sep 21, 2023 at 07:00 PM
MintMar
p.1 #14 · p.1 #14 · Canon 11-24 f4 filter system
The ultrawide lenses could be made smaller/cheaper compared to their EF counterparts. Wide end is where mirrorless should have lens-size/weight/price advantage over SLR.
An internal zooming 70-200/2.8 will be always a big barrel everywhere.
Sep 28, 2023 at 11:48 AM
Cnyphotoguy
p.1 #15 · p.1 #15 · Canon 11-24 f4 filter system
Agreed, the drop-in filter adapter and 11-24 combo has been great on my RP/R6m2 bodies. Use the Canon CP and Kolari clear/VND.
Sep 29, 2023 at 03:16 PM
