Are There Any RF to FE Adapters?
snegron7
p.1 #1 · p.1 #1 · Are There Any RF to FE Adapters?
I have seen several EF/FE adapters on the market, but I haven't found any RF/FE adapters. I'd like to use my Canon RF lenses on my A7c.
Sep 15, 2023 at 01:39 PM
InFocus2014
p.1 #2 · p.1 #2 · Are There Any RF to FE Adapters?
Due to the short flange distance on Sony bodies, that would not be possible, as far as I know.
Sep 15, 2023 at 01:42 PM
tsdevine
p.1 #3 · p.1 #3 · Are There Any RF to FE Adapters?
Well, from a flange distance perspective:
Z - 16mm
E - 18mm
RF - 20mm
There is a E to Z adapter….so in theory maybe an RF to E adapter is possible. Might be pretty tight towards the grip though, given the girth of RF lenses towards the mount (due to the diameter of the RF mount. Given that E is narrower than Z, it’s seems like an easier mechanical problem to solve than RF to E.
Edited on Sep 15, 2023 at 06:03 PM · View previous versions
Sep 15, 2023 at 02:17 PM
Butterfingers
p.1 #4 · p.1 #4 · Are There Any RF to FE Adapters?
From what I heard, it might not be possible because the RF lenses go inside the body quite a bit, and that the flange distance isn't necessarily the only concern when it comes to adapting RF lenses to FE.
However, I can't see why you couldn't develop a lens adapter for lenses that are also made for Sony FE. The reason why I want this is that I have both Sony and Fuji cameras both with about 16mm flange distance, it would be nice if I could use a RF manual focus lens on both of those camera systems.
Sep 15, 2023 at 03:56 PM
knshshnk
p.1 #5 · p.1 #5 · Are There Any RF to FE Adapters?
the diameter makes it impossible
Sep 15, 2023 at 04:19 PM
