Greece Trip
Laslo Varadi
p.1 #1 · p.1 #1 · Greece Trip
I will be going to Greece on vacation and taking the A1. Will be visiting Athens, Santorini, Mykonos and Crete. Thinking of taking just one lens. Either the Tamron 28-200 or the Sony 24-70 GMII. Which would you suggest for a lightweight kit?
Sep 09, 2023 at 06:11 AM
Douglas L
p.1 #2 · p.1 #2 · Greece Trip
Laslo, i would take the 24-70II, and a small UWA like the Voigtlander15. have a great trip!
Sep 09, 2023 at 07:10 AM
lensfan
p.1 #3 · p.1 #3 · Greece Trip
There is a lot of blue color in Greek photos. Would one benefit from using Zeiss optics in Greece?
I used 24-70 in Greece as a one lens solution. When I traveled light to Greece - I just took iphones with me.
Sep 09, 2023 at 07:23 AM
Laslo Varadi
p.1 #4 · p.1 #4 · Greece Trip
Hi Doug - I don’t have an ultra wide, but I can take the 24-70 and for low light the Sony 35 1.4
Sep 09, 2023 at 07:48 AM
tomjsimcock
p.1 #5 · p.1 #5 · Greece Trip
I'd take the 24-70 as the width will come in handy in Athens, especially if going up the Acropolis. the 24-70 and A1 should be good in low-light with cranking up the ISO. On the A7C, I can easily manage 3200 with very little noise.
Sep 09, 2023 at 08:17 AM
1bwana1
p.1 #6 · p.1 #6 · Greece Trip
I have been to all of those places. The variety of images available is huge. Many will benefit from the reach and compression of a long lens. I would take the 28-200mm Tamron, and add the 17-28mm Tamron. Buy or rent one, you should really have an ultra wide in your kit anyway.
The long FL images will likely be taken when there is plenty of light (almost every day fortunately) so the slower aperture will not be much of an issue. The towns and evening activities will mostly require wide FL and both of these lenses are fast enough in those FLs. As much as I love my Voigtlander 15mm, it is too slow for evening and walking around the villages where the best images are made.
On the islands (including Crete) the evening shots with village lights on can be spectacular. Fortunately these are mostly shot from vantage points where there are rocks or structures to put the camera on. I would still recommend that you take at least a good quality mini tripod for those shots. They are easy to travel with. You can place it on a rock, wall, or other structure and manage to get a slow SS shot for proper exposure or bracketing.
The above whole kit should easily fit in a small day or messenger bag, so will not be a burden when touring.
Edited on Sep 09, 2023 at 09:25 AM · View previous versions
Sep 09, 2023 at 09:12 AM
LBJ2
p.1 #7 · p.1 #7 · Greece Trip
A1 + GM 24-70 II. But I would be very tempted to bring the GM 70-200II too Ha!. But for one lens, all day--the GM 24-70II easy 😎
Sep 09, 2023 at 09:20 AM
j4nu
p.1 #8 · p.1 #8 · Greece Trip
On Crete and whereabouts I was mainly shooting 35-150, but had 14-24 to fall back on. Still, I didn't find the range limiting, it was mostly when I wanted a change in perspective that I switched...
Sep 09, 2023 at 09:48 AM
Laslo Varadi
p.1 #9 · p.1 #9 · Greece Trip
I picked up a Tamron 17-28 and will take that with the Sony 24-70 (or maybe the Tamron 28-200 ). Thank you all for your suggestions.
Sep 09, 2023 at 01:20 PM
1bwana1
p.1 #10 · p.1 #10 · Greece Trip
Great choices. Take a look at the 28-200 thread. I took that lens on a Fall Color photography trip I took to Colorado a couple of years ago. I shot it side by side at the same FL and apertures with my best primes. I posted samples in that thread. It held up surprisingly well, but not at their level. Better than I had expected for an all in one travel zoom. I don't think it is the equal of the Sony 24-70 GII however.
Here are a couple images with the Tamron 28-75 from that test trip. I would not have gotten the Fox image at all without the reach and flexibility of the Tamron.
Sep 09, 2023 at 07:27 PM
Frogfish
p.1 #11 · p.1 #11 · Greece Trip
Nailed it.
I'd just like to add that a UWA (at least 17mm is an absolute imperative. 24mm is definitely not enough for WA shots in narrow alleys. Don't have one? Rent one - it'll cost next to nothing.
Sep 10, 2023 at 03:00 AM
