Post-Processing iPhone 14 photo?
AFC168
p.1 #1 · p.1 #1 · Post-Processing iPhone 14 photo?
I have a pic taken with iPhone that I would like to print at 20x30 or larger. Are there people who specialize in taking small landscape files and making adjustments (photoshopping) to improve the image and make it more sense so it can be printed at 20x30? Would you know a reasonable cost for this?
Thanks!
Sep 01, 2023 at 10:20 PM
dclark
p.1 #2 · p.1 #2 · Post-Processing iPhone 14 photo?
John Watts is in the San Diego area and offers processing and printing services. You may want to look at this web site. https://wattsdigital.com/home
IMO, Making a 20x30 out of an iPhone photo will require some considerable skill.
Dave
Sep 01, 2023 at 11:24 PM
AFC168
p.1 #3 · p.1 #3 · Post-Processing iPhone 14 photo?
Thank you. Maybe I should also look to see if a plug-in can make the photo look more like a less precise painting.
Dave
Sep 02, 2023 at 10:12 PM
Abbott Schindl
p.1 #4 · p.1 #4 · Post-Processing iPhone 14 photo?
There are post-processing techniques for up-sizing images using Photoshop and other apps. One way is to repetitively upsize by relatively small factors. For example, if you want to increase the image size by 100% (i.e. make it twice as big), an old technique is to upscale nine or ten times of 10% each.
However, you're hoping to magnify something like ≥20X, which is asking a lot. Definitely talk to a pro. Also, keep in mind that the final print may not look as good as something like 8X10 because magnifying so much will magnify noise and artifacts, and color/clarity may not meet your expectations.
You might want to read through this article:
https://fixthephoto.com/best-photo-enlargement-software.html
Sep 03, 2023 at 10:10 AM
Burnard
p.1 #5 · p.1 #5 · Post-Processing iPhone 14 photo?
You might want to look into Topaz Gigapixel software. It specifically upsizes smaller images and also includes noise reduction and sharpening if needed. You could try a demo version of the software on your image. If your original image is good quality to start with you might be surprised what you can get.
Sep 05, 2023 at 12:08 PM
EB-1
p.1 #6 · p.1 #6 · Post-Processing iPhone 14 photo?
Unfortunately Topaz Gigapixel is EOL. They want you to buy the Photo AI now.
Sep 05, 2023 at 02:49 PM
CanadaMark
p.1 #7 · p.1 #7 · Post-Processing iPhone 14 photo?
Thanks!
All they are going to do is run it though some kind of up-res software, which many people here could do for you I'm sure. Maybe a few other quick tweaks. After that you can just send it to your printer of choice. If you don't want to do that, just make sure you aren't paying much for whatever service you use as this is most likely a very low effort job. I'm assuming it was shot in JPEG which means editing leeway will be very limited anyway.
20X30 is pretty big for what I assume is a 12MP photo but as long as you're not expecting miracles and as long as the viewing distance for the print isn't too close, you will probably be satisfied. If you print it on canvas that also helps as it's a very forgiving medium.
PM it to me if you want, I'll do a quick edit and up-res it for you.
Sep 06, 2023 at 10:33 AM
Burnard
p.1 #8 · p.1 #8 · Post-Processing iPhone 14 photo?
I sent you a PM.
Sep 07, 2023 at 08:14 PM
Burnard
p.1 #9 · p.1 #9 · Post-Processing iPhone 14 photo?
Thanks!
I sent you a PM.
Sep 07, 2023 at 10:09 PM
