600EX On Camera Master Group?
James Cripps
p.1 #1 · p.1 #1 · 600EX On Camera Master Group?
I should know this, but if I use one of my 600EX RT speedlites as a master flash in group mode (mounted on camera) and I want it to contribute flash to the exposure; which group is the on camera flash in? Does it just default to being “A”? I need to be able to adjust its exposure and don’t see any way to do this, unless it is indeed “A” flash. If that’s the case I suppose I’ll just move my “A” slave to another group, so I can control the independently.
*upon testing - it does seem to be in the “A” group, even though there’s no indication of it. I tried dialling down the A group EC to -3 stops, and it appears to be darkening the on camera master when I do this.
Aug 31, 2023 at 09:04 PM
rscheffler
p.1 #2 · p.1 #2 · 600EX On Camera Master Group?
I have always assumed it was A group but thanks for doing some tests to confirm it.
Would like to know if you run into any problems with lost connections between the master and remotes during your sessions.
Aug 31, 2023 at 11:46 PM
