Fred Miranda Offline Admin Upload & Sell: On
| p.1 #1 · p.1 #1 · Sigma 23mm f/1.4 and 100-400mm f5.0-6.3 for X-mount Announced | |
Sigma has announced that they are introducing two new lenses, the 100-400mm f/5-6.3 DG DN OS and the 23mm f/1.4 DC DN Contemporary, for Fujifilm X-mount. This addition increases the total number of Sigma lenses available for this format to six.
Among these lenses, the 100-400mm f/5.6-6.3 is the second zoom lens that Sigma has made for Fujifilm X-mount. It joins the 18-50mm f/2.8 DC DN lens in this category. On the other hand, the 23mm f/1.4 DC DN joins the group of fast prime lenses available for the mount, including the 16mm f/1.4, 30mm f/1.4, and 56mm f/1.4 options.
Sigma's 100-400mm lens, initially designed for full-frame cameras and released in 2020 for Sony E and Leica L mounts, now arrives for X-mount. Adapted with care for this format, Sigma has tailored a control algorithm for Fujifilm's APS-C cameras. This algorithm enhances autofocus drive, communication speed, and supports continuous autofocus (AF-C) along with in-camera aberration correction. The lens's side switches have been optimized for X-mount usage. The "AF Function Setting Switch" empowers photographers to select functions while pressing the AF Function Button on the lens.
Sigma is fulfilling its commitment to introduce the 23mm f/1.4 DC DN to Fujifilm X-mount. This APS-C lens is currently accessible for Sony E and Leica L mounts, and its upcoming availability for Fujifilm X was announced in April.
Sigma 23mm f/1.4 DC DN to Fujifilm X-mount Specifications
Pre-order it at B&H Photo ($549)
Maximum Aperture f/1.4
Minimum Aperture f/16
Lens Mount FUJIFILM X
Lens Format Coverage APS-C
Minimum Focus Distance 9.8" / 25 cm
Macro Reproduction Ratio 1:7.3
Optical Design 13 Elements in 10 Groups
Diaphragm Blades 9
Focus Type Autofocus
Image Stabilization No
Filter Size 52 mm (Front)
Dimensions (ø x L) 2.6 x 3" / 65.8 x 76.9 mm
Weight 12 oz / 340 g
Sigma 100-400mm f/5-6.3 DG DN OS to Fujifilm X-mount Specifications
Pre-order it at B&H Photo ($949)
Maximum Aperture f/5 to 6.3
Minimum Aperture f/22 to 29
Lens Format Coverage Full-Frame
Angle of View 24.4° to 6.2°
Minimum Focus Distance 3.61' / 1.1 m
Maximum Magnification 0.24x
Optical Design 22 Elements in 16 Groups
Diaphragm Blades 9, Rounded
Image Stabilization Yes
Tripod Collar Removable and Rotating (Optional)
Filter Size 67 mm (Front)
Dimensions (ø x L) 3.39 x 7.76" / 86 x 197.2 mm
Length at Maximum Extension 10.92" / 277.3 mm
Weight 2.5 lb / 1135 g
