vbnut Offline Upload & Sell: Off
Nice shots. You're off to a good start.
FWIW, whether you know it or not, capturing ball compression like you did in #4 is quite difficult. Nice work (but see below). Several Dig Magazine (I think it was them, they're since out of business) had a feature article show the ball compression photos from their entire staff of contributing professional photographers from an entire AVP season (IIRC). They only had a couple dozen images, and each of those photographers shoots thousands of shots every tournament.
Here one tip, for sports photography in general, that I've read multiple times over the years, and still have to remember to focus on.
Prioritize (1) face, (2) ball, (3) peak action, in that order.
The best shots have all 3, and eventually you'll probably get to the point that you'll delete most shots that don't. #4 would be a prize winner (IMO), but its missing the face. I find its helpful to decide who your subject(s) is(are), and what action you want to capture them doing, then position yourself so you'll see their face when they perform the action. For example when shooting indoor volleyball I'll move to different locations around the arena/gym to capture hitters and blockers for one of the teams (the other team will have their back to me), or setters, passers and diggers (again typically one position will only be able to get good shots of one of the teams, but fortunately the teams switch sides between sets).
FWIW, with beach volleyball I try to position myself with the sun mostly behind me. That typically means I focus on shooting the players on the far side of the court, since they are facing me, and then shoot the other team when they switch sides. When there are line judges standing at some corners of the court, I have to compromise a but I still try to avoid shooting into the sun, which will result in the faces being in shadows. When I attend AVP or FIVB beach volleyball events, it is interesting to see all the professional photographers crowded in one corner of the court (where the sun is behind them) and the other three corners empty.
As @farwest said, try shooting in portrait orientation (especially for net play). Volleyball is mostly tall, lean players, and with the exception of passing and digging, they're doing "vertical" things. Portrait will make it easier to avoid cutting off the limbs of spikers and blockers. In addition, one of the cool things, IMO, is seeing the sand the players kick up when jumping, and that is more likely to be visible when shooting portrait. I'm typically not quick enough to rotated between landscape and portrait in the middle of a rally (maybe pro photographers are), so I usually decide before the serve whether I'm going to focus on net or back court play for that rally, and pick portrait or landscape as appropriate.
You may find shooting beach volleyball can be addictive as you can often get closer to the action (without a media credential) than you can with other sports.
