artsupreme Offline Upload & Sell: On
EB-1 wrote:
It's about f/8 for 45MP FX (or a little less than that for 50MP) based on extinction resolution. The DLA can be more or less depending on your interpretation of impact, e.g., do you chose 2x, 2.5x or 3x for Airy disk size relative to pixel size. My point is that f/14 is two stops past the 2.5x so closer to 5x, which will be visible (more with a good lens and weak AA filter). Some people are more sensitive to resolution than others, and processing can of course increase contrast (unsharp mask) or use deconvolution sharpening, AI, etc. to make the image still look good.
IIRC it has been discussed several times at FM that the sharpness is more important to the casual viewer than resolution. If f/11 or f/14 looks good to you, then it's fine to use. Just know you are not getting the full amount of possible detail. I have over 100K frames on various 5DsRs and know how it behaves. I mostly avoided smaller apertures than f/8 and only f/11 when really needed, but it's not as sharp. At f/8 you can see sometimes have a reduction of moire from wider apertures. I use f/8 with the R5, but mostly pan and focus stack landscapes. The R5 does not have the resolution of the 5DsR. It also has a noticeable AA filter, so any slight diffraction at f/8 is minimal to the overall image. And we all know that lenses (especially zooms) may need f/8-10 for the best corners, either due to filed curvature or other optical aberrations.
EBH...Show more →
So for an occasional landscape shot on the R5 with let's say a 14-35mm around 18-20mm, you would suggest using f/8 and focus stacking 3 or 4 images (foreground, middle, background)? Or, would you take more than a few images to stack if shooting at f/8?
