EB-1 Offline Upload & Sell: Off
p.1 #6 · p.1 #6 · 500mm f4 Version I, question about extenders with R body | |
grendel64 wrote:
Hi folks, I did some searching and from what I've seen posted, the EF 500mm f4 (first iteration) should work with an EF extender (1.4) on an R5 body using the EF to RF extender. However I'm having no luck using an EF 1.4 mk II in this scenario. Could it be that the first gen 500mm F4 just can't accomodate that combination, or is something else going on. The lens works great with just the EF-RF adaptor, but I get F00 when I connect the 1.4. Just wondering what might be going on.
Mike
It should work. As mentioned above it's probably a connection issue.
Consider getting a 1.4x III. Although the 500/4 IS was designed to work with the 1.4x and 1.4x II, the 1.4x III is significantly better, especially the lower CA and better IQ towards the edges. The difference compared to the 1.4x/1.4x II is more noticeable with 45-50 MP bodies than the 20MP and lower bodies. You will want to use ES to obtain a high framing rate with the R5, but you probably already know that.
