Front Element Moisture/Debris?
fotoman-81
p.1 #1 · p.1 #1 · Front Element Moisture/Debris?
Hello everyone!
Is anyone familiar with this problem? There appears to be some foreign matter under the front element of my EF 70-200 f2.8L IS II, but I'm not certain what it could be and if it's going to worsen.
Here is an image of the front of the lens (external link to the photo as I'm not an Upload&Sell member.)
https://photos.app.goo.gl/VqXvkr7ffgHBUmJj9
Aug 17, 2023 at 11:30 AM
AmbientMike
p.1 #2 · p.1 #2 · Front Element Moisture/Debris?
Not sure, I'd probably keep using it at this point. Any iq issues? Doesn't look like fungus or moisture to me, maybe some sort of glue?
Aug 17, 2023 at 11:57 AM
mgrabow250
p.1 #3 · p.1 #3 · Front Element Moisture/Debris?
Did you try cleaning the front of the lens yet? I just looked at my 70-200 and was surprised to see how dirty it was. Like someone sneezed on it. I used my breath and a micro fiber cloth and after a few wipes it shines like new. From your picture it looks like something dried up on the glass.
Mike
Aug 17, 2023 at 03:51 PM
fotoman-81
p.1 #4 · p.1 #4 · Front Element Moisture/Debris?
Mike,
It is under the glass.
Aug 17, 2023 at 07:45 PM
Jesse Evans
p.1 #5 · p.1 #5 · Front Element Moisture/Debris?
It kinda looks to me like Balsam separation. While balsam isn’t in use any more, it is still possible for lenses to begin separating if there are imperfections in the optics. The 70-200 2.8 II front element is cemented together with another element, it kinda looks like they’ve started separating at the edges. At least, it looks very similar to the beginning of balsam separation to me.
Aug 17, 2023 at 11:40 PM
p.1 #6 · p.1 #6 · Front Element Moisture/Debris?
The only other thing not yet mentioned, that I can think of, is also from the olden days. The grease used to lubricate lens helical gears was a problem in high temps, as the old grease could separate into three components;
(i) hard, dry stuff, that makes for 'stiff' (or stuck) focus and zoom rings, on old lenses;
(ii) oily, fluid stuff, that often ends up on the aperture blades, and makes them sluggish (or stuck);
(iii) and vapour, that can condense elsewhere in the lens, often on internal elements.
This problem could be either of the last two cases, but I haven't seen it. My EF 70-200/2.8L IS II has seen at least two months of trunk- and hand-time in the Utah deserts (over four or five years), and it is fine. OTOH, it's hotter now.
Aug 18, 2023 at 11:55 AM
